minion
column switcher linked multiple platform
dt = Open( "$SAMPLE_DATA/Process Measurements.jmp" );
clear log();
colnames = dt << getcolumnnames(numeric,string);
colnames = Filter Each({name}, colnames, !Is Missing(Regex(lowercase(name), "^(process).*")));
print(colnames[1]);
New Window("reacher",
	H List Box(
		V List Box (
			dist = dt << Distribution(Continuous Distribution(Column(column(dt, colnames[1])),Process Capability( 0 )),Histograms Only),
			biv = Bivariate( Y(column(dt, colnames[1])), X(column(dt, colnames[1])) )
		cs = dt << Column Switcher(:Process 1, colnames),
//		cs = dt << Column Switcher(colnames[1], colnames),
cs << Link Platform( dist );
cs << Link Platform( biv );
Trying to script column switcher for arbitrary table.
Code above works.
However, when line16 is commented and line17 uncommented, column switcher does not work
Please help
Re: column switcher linked multiple platform
You might have to evaluate the colnames[1] in correct format to column switcher. Here is one option
dt = Open("$SAMPLE_DATA/Process Measurements.jmp");
colnames = dt << getcolumnnames(numeric, string);
colnames = Filter Each({name}, colnames, !Is Missing(Regex(Lowercase(name), "^(process).*")));
Eval(EvalExpr(
	nw = New Window("reacher",
		H List Box(
			V List Box(
					Continuous Distribution(Column(Eval(colnames[1])), Process Capability(0)),
					Histograms Only
				biv = Bivariate(Y(Eval(colnames[1])), X(Eval(colnames[1])))
			cs = dt << Column Switcher(Expr(NameExpr(AsColumn(dt, colnames[1]))), colnames)
cs << Link Platform(dist);
cs << Link Platform(biv);
Eval(EvalExpr(
		H List Box(
			V List Box(
					Histograms Only
minion
Thanks for the note.
If the column name has special characters in the name, the expression does not work
Example columns: "Process:USL=8:LSL=1.0"
Which JMP version are you using?
Works fine for me (using JMP18.0.1)
View more...
Column(dt, 1) << Set Name("Process:USL=8:LSL=1.0");
Eval(
	Eval Expr(
			H List Box(
				V List Box(
						Histograms Only
					Expr(
						Name Expr(As Column(dt, colnames[1]))
					colnames
