BookmarkSubscribeSubscribe to RSS Feed
Re: column reference plot of graph builder
vishwasanj
Community Trekker
Dec 27, 2016
Thank you for giving amazing suggestions.
I encountered something else and I have always been curious about this. Whenever I come across this, I try to stack to circumvent the problem.
In a graph builder, how to plot without knowing the name of the column
collist =fudt<< get column names(string);
qdt=Char(collist[9]); //Assuming I want to plot column number 9 on the Y axis, say for example "Data_ABC"
gbfc = fudt<<Graph Builder(
Size( 1899, 922 ),
Variables(
X( :Index ),
X( :Lot, Position( 1 ) ),
X( :Wafers, Position( 1 ) ),
Y( :qdt),// THIS DOESN't WORK - I want to understand the syntax
Color( :temp )
Elements( Points( X( 1 ), X( 2 ), X( 3 ), Y, Legend( 33 ) ) )
Thank you.
uday_guntupalli
Community Trekker
Sep 15, 2014
Solution
@vishwasanj
cdlg = Column Dialog( clist = ColList( "Pick 2 Columns", Min Col( 2 ), Max Col( 2 ) ) );
cols = cdlg["clist"];
newColExpr = Expr( dt << New Column( "Radius", Numeric, Formula( Sqrt( Expr( cols[1] ) ^ 2 + Expr( cols[2]; ) ^ 2 ) ) ) );
Eval( Eval Expr( newColExpr ) );
https://community.jmp.com/t5/Discussions/JSL-Creating-formula-using-a-variable-column-name/td-p/942/...
Best
Uday
uday_guntupalli
Community Trekker
Sep 15, 2014
Solution
@vishwasanj
Best
Uday
vishwasanj
Community Trekker
Dec 27, 2016
That was cool. Thank you Uday.
pmroz
Jun 23, 2011
Your variable qdt points to the name of the column.  It is not a column itself.  You have to reference it using the construct column(fudt, qdt):
gbfc = fudt << Graph Builder(
	Size( 1899, 922 ),
	Variables(
		X( :Index ),
		Y( Column( fudt, qdt ) ), 	// use column pointed to by the qdt variable
		//Y( :qdt),	// THIS DOESN't WORK - I want to understand the syntax
		Color( :temp ),
vishwasanj
Community Trekker
Dec 27, 2016
Interesting. Let me try that syntax. Thank you pmroz
GoodMan
Community Trekker
Oct 28, 2011
Uday,
Thanks for your post. Here i can see the fomula code as follows. Can you explan what means cols&#91;1&#93 and  cols&#91;2&#93?
Formula( Sqrt( Expr( cols&#91;1&#93; ) ^ 2 + Expr( cols&#91;2&#93; ) ^ 2 ) )
uday_guntupalli
Community Trekker
Sep 15, 2014
@GoodMan,
Thanks for pointing out . I recollected and recalled that from the post . Not the way I would do it .
ColNames = dt << Get Column Names("String");
Stmt = "";
Stmt = ":" || ColNames[2] || "*2";
Eval( Parse( Eval Insert("\[ dt << New Column("Age_Squared",Numeric,Continuous,Formula(^Stmt^)); ]\" ) ) );
Best
Uday
GoodMan
Community Trekker
Oct 28, 2011
Thanks. Following your new code, go back the the previous example, still i have some problem. Can you help me?
newColExpr = Expr( dt << New Column( "Radius", Numeric, Formula( Sqrt( Expr( cols ) ^ 2 + Expr( cols) ^ 2 ) ) ) );
GM
GoodMan
Community Trekker
Oct 28, 2011
Uday,
I checked your previous code again. Now i understand that &#91=[. So now I can figure it out now. Thank you anyway!
GM
Jeff_Perkinson
Community Manager
Jun 23, 2011
Those were meant to be square brackets. I've edited the post and corrected that.
-Jeff
