arnow
column names in lists
I'm quite unfamiliar with JMP scripting and have the following problem: In a production environment, there are several process steps and for each process step there several tools. At the end measurements are performed and i need to create tool-trends for theses measurements where the measurements is on the y-axis, the date is on the x-axis and the data are group by the tool used for the lots. In order not to repeat essentially the same code several times i try the follwing for a particular measurement:
First, i create a tool-list und a date list:
tool_list=list("Tool1", "Tool2", "Tool3");
date_list=list("Date1", "Date2", "Date3");
Next, i use for to loop through the lists:
for(i=1, i<= nitems(tool_list), i++, ...)
Now, the items in each list are column names in the data table and i need to assign these to the graph builder platform. I tried something like this:
Variables(X(date_list(i)), Y(measurement1), Group Y(tool_list(i))
However, JMP does not recognize, that date_list(i) is a column name. Is there a way to specify that?
Thanks for any help!
Regards
Arno
pmroz
You need to use square brackets instead of parentheses for referencing list elements.  Here's an example:
dt = open("$sample_data\Car Physical Data.jmp");
xlist = {"Gas Tank Size", "Weight"};
ylist = {"Displacement", "Horsepower"};
glist = {"Type", "Country"};
for (i = 1, i <= nitems(xlist), i++,
    print(i);
    Graph Builder(
        Show Control Panel( 0 ),
        Variables( X( column(dt, xlist[i]) ),
                Y( column(dt, ylist[i]) ),
                Color( column(dt, glist[i]) ) ),
        Elements( Points( X, Y, Color, Legend( 2 ) ) ),
        SendToReport( Dispatch( {}, "Graph Builder", FrameBox, {Marker Size( 3 )} ) )
pmroz
    print(i);
    Graph Builder(
arnow
Re: column names in lists
Ok, here is the repost:
Thanks, it works now. But another problem came up: I need to configure the axes. The code, that formerly worked is:
prec = New Window( "Shunts vs PREC",
      dt << Graph Builder(
            Size( 853, 558 ),
            Show Legend( 0 ),
            Lock Scales( 1 ),
            Variables( X( :Precursor, Size( 120 ) ), Y( :Shunts ), Group Y( :Anlage2 ) ),
            Elements( Points( X, Y, Legend( 2 ) ), Smoother( X, Y, Legend( 3 ) ) ),
                  Dispatch(
                        "Precursor",
                        ScaleBox,
                        {Min( start_datum - tag ), Max( end_datum ), Interval( "Day" ), Inc( date_inc ), Minor Ticks( 0 ),
                        Rotated Labels( 1 )}
                  Dispatch(
                        "Shunts",
                        ScaleBox,
                        {Format( "Best", 12 ), Min( -0.1 ), Max( 12 ), Inc( 1 ), Minor Ticks( 1 ),
                        Add Ref Line( 4, Solid, {255, 0, 0} ), Show Major Grid( 1 ), Rotated Labels( "Automatic" )}
I just copied this code from the "copy script" option of the graph. Unfortunately I hardly understand the code. The updated version using lists does not do anything with the axes:
date_list = List( "Precursor", "CIS" );
tool_list = List( "Anlage2", "Anlage3" );
            Size( 853, 558 ),
            Show Legend( 0 ),
            Lock Scales( 1 ),
            Variables(
                  X( Column( dt, date_list[i] ), Size( 120 ) ),
                  Y( :Shunts ),
                  Group Y( Column( dt, tool_list[i] ) ),
                        Dispatch(
                              date_list[i],
                              ScaleBox,
                        Dispatch(
                              "Shunts",
                              ScaleBox,
Thanks and regards Arno
pmroz
ArnoW,
I'm having trouble understanding your code.  Perhaps you could repost it with some formatting?
Right click on the code in a JMP script window and select Reformat Script.
Then copy/paste the code from JMP into a blank Word document.  Recopy it from Word and paste it into a reply window in this forum.  That's how I was able to post the formatted code.
Regards,
Peter
