  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
judith
Which function could quickly remove the blank in front of string?
Which function could I use to remove the blank in front of string? Is there any function that works like left() of SAS? Thanks.
pmroz
There doesn't appear to be an LTRIM function.  Here's one way to do it, using a regular expression.
Function Name: ltrim
Description: Trim any spaces on the left side of a string.
Arguments:
in_string   String to do the left trim on
Sample calls:
   a = "   ddd   eee fff   ";
   print(ltrim(a));
   c = "abcde";
   print(ltrim(c));
ltrim = Function( {in_string},
      {Default Local},
// Use the regular expression "^ *" which means start at the beginning of the string
// and match any number of sequential spaces
      start_nonspace = length(Regex(in_string, "^ *"));
      ltrim_string   = substr(in_string, (start_nonspace+1));
      ltrim_string;
pmroz
Arguments:
Sample calls:
   print(ltrim(a));
   c = "abcde";
   print(ltrim(c));
      {Default Local},
      ltrim_string;
judith
Thanks a lot for your instruction again. Your answer is always helpful.
ms
Super User (Alumni) ms
Trim() supports an optional "left", "both" or "right" argument. Default is to trim trailing whitespace at both ends.
s = "   Column Name ";
Trim( s, left );
judith
That was a quick and simple answer. Thanks for your input.
pmroz
I should have RTFM'd.  Thanks for pointing that out MS!
