Level XIII
color settings for "missing" values
If there is a value missing in the data table, "missing" shows up as the first entry in the legend - and shifts all colors by 1 :(
Is it possible to define the value order in the column preferences such that "missing" is last?
Is it possible to define this as a standard via preferences?
Or even better: Is it possible to define a fixed color for "missing" values - such that it doesn't interfere at all with the standard color order?
dt << Graph Builder(
	Size( 534, 464 ),
	Graph Spacing( 4 ),
	Variables( X( :weight ), Y( :height ), Overlay( :sex ) ),
	Elements( Points( X, Y, Legend( 9 ) ), Smoother( X, Y, Legend( 10 ) ) )
wait(2);
dt:sex[5]="";
Re: color settings for "missing" values
What you need to do is to set the Value Colors for the column in question.  The limitation is that you do not want to use the #1 color in your choice.  Reserve that for the Missing Category
names default to here(1);
:sex << set property("Value Colors", {"F" = "blue", "M" = "green"});
	Size( 534, 464 ),
	Graph Spacing( 4 ),
wait(2);
dt:sex[5]="";
9 REPLIES 9
You could use Value Colors column property but... if you use it it seems like the missing value color in the theme will be ignored. I would say this is a bug and should be reported to JMP support.
By default the user's preference color theme should be used AND the missing values should be with the desired color, but for some reason this doesn't seem to be the case
With Value Colors (missing color will be ignored)
Without Value Colors (weird shift as the missing color is used but first color is still skipped)
I'm using Universal color theme here
Apparently you have the option, "Include Missing Categories" selected as your default.  You can tun this off by unselecting it under the red triangle.
Or the option can be set as a default  as a preference
The order of Missing Categories can also be adjusted under the "Legend Settings" selection under the red triangle
Level XIII
Hi Jim,
thanks for the explanations.
To be honest, I don't understand which part of it solves my problem:
 I face this problem very often in JMP and want to solve it in general.
Below is another example, which makes the problem slightly more visible:
"sex" and "sex_2" are "the same", there is just one value missing in one cell of the data table.
I expect the color schemes to be the same (*) "by default" - without any additional effort.
How can I configure JMP to make it behave like expected (*)?
View more...
dt << New Column( "sex_2", Character, set each value( :sex ) );
New Window( "compare",
	H List Box(
			Size( 534, 464 ),
			Graph Spacing( 4 ),
			Size( 534, 464 ),
			Graph Spacing( 4 ),
			Variables( X( :weight ), Y( :height ), Overlay( :"sex_2" ) ),
Wait( 2 );
dt:sex[5] = "";
	Size( 534, 464 ),
	Graph Spacing( 4 ),
wait(2);
dt:sex[5]="";
Level XIII
Hi Jim,
you are right, this is indeed the most robust way to do it: minimum effort, but no surprises anymore :)
That was my first attempt to solve the issue, but ...
Ah:
Many thanks. Nice workaround for this secon-order issue :)
Next step:
Where is the column property setting hiding to define the "Value Markers"?
There is not an equivalent "Value Markers" to the "Value Colors".  Markers are set either by Row State
dt << Marker by Column( :sex );
Graph Builder(
	Variables( X( :height ), Y( :weight ), Color( :age ) ),
	Elements( Points( X, Y, Legend( 1 ) ) )
Or by specific changes to elements within the Graphic platform
Graph Builder(
	Size( 525, 454 ),
	Variables( X( :weight ), Y( :height ), Color( :sex ) ),
	Elements( Points( X, Y, Legend( 9 ) ), Smoother( X, Y, Legend( 10 ) ) ),
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				9,
				Properties(
					0,
					{Marker( "FilledWide" ), Marker Size( 6 )},
					Item ID( "F", 1 )
Level XIII
Oh, I am a bit surprised that the column propery: Value Markers is not yet available.
Here is the wish:
new Column Property: Value Markers
Marker by Column().
I guess there are some applications where it makes sense, but there are so many disadvantages ...
Level XIII
@hogi wrote:
... Value Markers is not yet available.
Here is the wish:
https://community.jmp.com/t5/JMP-Wish-List/new-Column-Property-Value-Markers/idi-p/565358
Unfortunately, the wish got rejected :(
nobody needs Value Markers ?
Level XIII
The status of new Column Property: Value Markers just changed from "Not Planned for Now" to "Acknowledged".
-> again open for voting:
Up to now, the Wish got 6 Kudos. Not bad - but ...
Just imagine how helpful it could be:
- meaningful legends in Graph Builder (compared to the alternative via row states)
- fully automatic + consistent  (compared to assigning markers manually via legend - right click menu)
interested? Follow the link and support the Wish with a Kudo.
