djhanson
col<
Anyone know of any 'simple' syntax to do this?  col<<get values gets all of the column's row values (excluded, included, etc).  Would be cool if their was some obscure JSL column message to get a column's rows which are not excluded.  Let me know if you know... thx, dj
ms
Super User (Alumni) ms
col<
Not pretty but it returns a matrix of the values of non-excluded rows.
col[dt << select where( Excluded(Row State()) != 1 ) << get selected rows]
8 REPLIES 8
ms
col<
djhanson
col<
MS, thanks a bunch!  That's exactly what I was looking for and works perfectly for my needs .  dj
Level XIII
Re: col<
Very old post ...
is there now a better way to do this?
Why is there a
dt << Get Excluded Rows();
but no
dt << Get nonExcluded Rows();
Level XIII
Re: col<
what is the fastest way to get
in JMP 17 for a data set with 10 mio rows - without changing the selection?
Re: col<
nonExcluded = dt << get rows where( Excluded( Row State( Row() ) ) == 0 );
Re: col<
Not sure about the fastest but this should work (it might need some additional error handling)
/* init */
dt << Select Rows([2,3,4,30]) << Exclude(1) << Clear Select;
// get row indices
excl_rows = dt << Get Excluded Rows;
all_rows = 1::N Rows(dt);
all_rows[excl_rows] = .;
all_rows = Loc(all_rows);
Also a good idea to keep in mind that fastest isn't always the best
Level XIII
Re: col<
Thanks.
I also added a version which scales linearly with # of excluded rows (ecluded rows are removed one by one).
It's quite competitive for small numbers of excluded rows, but performs worse and worse for large numbers.
Around 200 excluded rows it reached the performance of Jim's version and gets then really bad ...
In addition, I found a version ("Jim X"), which is ~ factor 2 faster than Jim's version - and even shorter code:
	nonExludedRows = dt << get rows where( Excluded() == 0 );
Most important:
Jarmo's version is by far the best.
View more...
dt = New Table( "dummy table" );
NR = 10E6;
dt << add rows( NR );
dt << New Column( "random", set each value( Random Uniform( 0, 100 ) ) );
For Each( {percent, idx},
	{0.00001, 0.00002, 0.00005, 0.0001, 0.0002, 0.0005, 0.001, 0.002, 0.005, 0.01, 0.02, 0.05, 0.1, 0.2, 0.5, 1, 2, 5, 10, 15, 20, 30, 40, 50, 60,
	70, 80, 90, 100},
	Print( percent );
	dt << Clear Row States;
	dt << select where( :random < percent );
	dt << Hide and Exclude;
	nexcl = N Rows( dt << Get Excluded Rows );
	dt << Clear Select;
	Wait();
	// Jim
	bt = HP Time();
	allRows = dt << get rows where( Excluded( Row State( Row() ) ) == 0 );
	et = HP Time();
	time1 = et - bt;
	// Jim X
	bt = HP Time();
	allRows = dt << get rows where( Excluded() == 0 );
	et = HP Time();
	time2 = et - bt;
	// Jarmo
	bt = HP Time();
	et = HP Time();
	time3a = et - bt;
	all_rows = 1 :: N Rows( dt );
	et = HP Time();
	time3 = et - bt;
	// hogi
	If( idx < 11,
		bt = HP Time();
		excl = dt << Get Excluded Rows;
		allRows = (1 :: N Rows( dt ));
		For Each( {i, j}, Reverse( excl ), Remove From( allRows, i, 1 ) );
		et = HP Time();
		time4 = et - bt;
	Wait();
	If( idx == 1,
		New Window( "timing results",
			tb = Table Box(
				Number Col Box( "# excluded", {Nexcl} ),
				Number Col Box( "Jim", {time1 / 1000000} ),
				Number Col Box( "Jim X", {time2 / 1000000} ),
				Number Col Box( "Jarmo", {time3 / 1000000} ),
				Number Col Box( "Jarmo (get ... rows)", {time3a / 1000000} ),
				Number Col Box( "hogi", {time4 / 1000000} ),
		If( idx < 11,
			tb << add row( {Nexcl, time1 / 1000000, time2 / 1000000, time3 / 1000000,time3a / 1000000, time4 / 1000000} ),
			tb << add row( {Nexcl, time1 / 1000000, time2 / 1000000, time3 / 1000000, time3a / 1000000} )
results = tb << Make Combined Data Table;
gb = results << Graph Builder(
	Variables( X( :"# excluded"n ), Y( :Jim ), Y( :Jim X, Position( 1 ) ), Y( :Jarmo, Position( 1 ) ), Y( :hogi, Position( 1 ) ) ),
	Elements( Points( X, Y( 1 ), Y( 2 ), Y( 3 ), Y( 4 ), Legend( 5 ) ), Smoother( X, Y( 1 ), Y( 2 ), Y( 3 ), Y( 4 ), Legend( 6 ), Lambda( 0.001 ) ) )
Report( gb )[AxisBox( 1 )] << {Scale( "Log" ), Min( 1 ), Max( 10000000 )};
Report( gb )[AxisBox( 2 )] << {Scale( "Log" ), Min( 0.1 ), Max( 10 ),Label Row( Show Minor Grid( 1 ) )};
Report( gb )[Text Edit Box( 4 )] << Set Text( "time [s]" )
Re: col<
Thank you for the suggestions. JMP 18 will implement a new series of JSL functions that improves the performance and readability of the specific query discussed here and other similar queries. Documentation has been updated also to reflect the preferred/faster methods.
The JSL looks something like this:
//instead of Get Rows Where()
Where( dt, Excluded() );
Where( dt, !Excluded() );
Where( dt, Hidden() );
Where( dt, !Hidden() );
Where( dt, Labeled() );
Where( dt, !Labeled() );
Where( dt, Is Missing() );
