juggernauttt
Question with natural log
I'm trying to set a variable to a natural log, but I do not know how to go about it.
Re: Question with natural log
Right-click on the column name in the data table and select New Formula Column > Transform > Log. This action adds a new data column. Is that result what you want?
  1. Create a new formula column, and set the formula to      Log(xxxx)    where xxxx is the column name you want to have the log transformation on
  2. Or, when running a graphical or statistical platform, when you go to select a column you want to be the log() of, jus right click on the column name and select     Transform==>Log
All of this is covered in the JMP Document,     Using JMP      it is available @ Help==>JMP Documentation Library         Using JMP
