change markers for selected points in a graph using JSL
I need to highlight some selected points on a plot. I can select them, but the selection does not show on saved plots, so as alternative, I want to change the markers of the selected points (i.e. rows).
It's probably just one line, but can't figure out how to do that. Could somebody advise, please?
Graph Builder(
	Variables( X( :height ), Y( :weight )),
dt << Select Where (:sex == "F");
//now I want to change the marker for the selected data
mmarchandFSLR
Re: change markers for selected points in a graph using JSL
You can send the <<Markers message to the data table when the rows you want are selected.
dt << Markers( "triangle" );
Level XIII
calculate a SIZE column from your selection (0/1) and use it as size in Graph Builder. Then you get different sizes for selected and non-selected points.
mmarchandFSLR
Level XIII
You have to save the selection as 0/1  into a column *) - and use that column as Overlay.
In your case, you can directly use SEX as Overlay.
* in the video I used the shortcut key from the Quickselect Toolbar . As an alternative,you can Name Selection in Column from the Rows/Row Selection menu,
(view in My Videos)
Level XIII
One major disadvantage of this approach is that: Overlay is often used for another purpose.
If you would like the option to use Overlay by multiple columns , please follow the wish and vote!
Another option:
Via right click - assign a Row State/Marker to the selected columns.
The disadvantage of this approach: row states are static, they don't adapt interactively to the current data!
Thanks @hogi, that's an interesting feature. Here though, I was looking for a JSL solution (which @mmarchandFSLR provided).
@mmarchandFSLR
Is there a similar way to change the size of the markers? Simply adding
Based on the example in the Scripting Index I tried a few approaches. The version below selects the right markers, but changes the size of all markers, not just the selected ones.
gb = Graph Builder(
rbiv = gb << report;
//rbiv << Select Where (:sex == "F");
framebox = rbiv[Frame Box( 1 )];
//framebox << Select Where (:sex == "F");
framebox << Marker Size( 7 );
dt << Marker Size( 7 );
Level XIII
