Katennika
Make F1 key customized (was Newb help)
In JMP 16 (Windows) , I removed the F1 hotkey from Help and set up as a new function using Custom Menus and Toolbars.
I did the same in JMP 17 standard, and yet when I hit F1, I still get the Help browser link.  Is there another place that F1 is set up that I am missing?  Or is it hardcoded?
Re: Make F1 key customized (was Newb help)
To my knowledge there are some shortcuts which cannot be modified and it seems like F1 is one of them (I have had to workaround quite a few of those "hard-coded ones"). I'm not sure if all of these are something which you cannot change JMP documentation (Keyboard Shortcuts).
