Hi @abmayfield ,
I hope the JMP and/or computer re-set did the trick. If not, I also went back and built a GUI for the NN modeling -- I plan on expanding it to work across different platforms. It doesn't work perfectly, and I get some strange errors at times (an expert scripter can probably debug it within seconds). But, the nice thing is that it will work with any type of input data column -- ordinal, nominal, and continuous, and it works with the acceptable validation methods for NN -- excluded rows, holdback, Kfold, and validation column. It will work with both validation columns that have Test data in them and ones that don't. It's the script called NN GUI in your data table (attached).
For those interested, I borrowed heavily on a blog from JMP staff .@juliagong (retired) here and a support note from .@Wendy_Murphrey here. I plan on creating a GUI that can automate this for the other platforms I have also automated from within data tables: boosted tree, bootstrap forest, and XGBoost. I plan on posting it in the community, but it could take some time -- especially to make sure it's fully debugged.
The only change from the below code to the GUI in the data table is changing dt = Data Table ("...") to dt = Current Data Table().
I hope this helps to make progress on your work. It does for me as I can improve this to make my modeling efforts easier, too!
Good luck,
DS
NN GUI code:
//Clear Symbols();
dt = Data Table( "Neural networking Ofav 2017 dataset" );
dt_parms = Data Table( "NN Tuning 8" );
nc = N Col( dt );
dtp_name = dt_parms << get name;
dt_name = dt << get name;
valid_list = {"Excluded Rows Holdback", "Holdback", "KFold", "Validation Column"};
//the width of the column list box in pixels
lbWidth = 110;
/* Expression to clear all current settings */
clearRoles = Expr(
colListY << RemoveAll;
colListV << RemoveAll;
/* Expression to store the current settings in global variables */
recallRoles = Expr(
::ycolRecall = colListY << GetItems;
::vcolRecall = colListV << GetItems;
VmethodDlg = New Window( "Choose Validation Type",
<<Return Result,
<<Modal,
<<OnValidate,
V List Box(
Align( center ),
H List Box( Spacer Box( Size( 10, 15 ) ), Text Box( "Automated Tuning" ), Spacer Box( Size( 10, 10 ) ) ),
Spacer Box( Size( 20, 10 ) ),
H List Box(
V List Box(
Panel Box( "Column Selection", colListData = Col List Box( All, nLines( Min( nc, 5 ) ) ) ),
V List Box(
Panel Box( "Validation Method", methodObj = Radio Box( valid_list ) ),
Panel Box( "Validation Options",
V List Box(
Text Box( "Holdback Portion" ),
HP_input = Number Edit Box( . ),
Spacer Box( Size( 10, 5 ) ),
Text Box( "Number of Folds" ),
KF_input = Number Edit Box( . )
V List Box(
Panel Box( "Cast Selected Columns into Roles",
Lineup Box( N Col( 2 ), Spacing( 3 ),
Button Box( "Y, Response", colListY << Append( colListData << GetSelected ) ),
colListY = Col List Box( width( lbWidth ), nLines( 1 ) ),
Button Box( "Validation Column", colListV << Append( colListData << GetSelected ) ),
colListV = Col List Box( width( lbWidth ), nLines( 1 ) )
Panel Box( "Action",
Lineup Box( N Col( 1 ),
//OK Button
Button Box( "OK",
recallRoles;
//script that executes upon clicking "OK"
If(
(MethodObj << Get) == 1,
VMeth = "Excluded Rows Holdback";
y_resp = ColListY << GetItems;
VmethodDlg << CloseWindow;,
(MethodObj << Get) == 2,
VMeth = "Holdback";
(MethodObj << Get) == 3,
VMeth = "Kfold";
(MethodObj << Get) == 4,
VMeth = "Validation Column";
ValidCol = ColListV << GetItems;
//Cancel Button
Button Box( "Cancel",
Break();
Button Box( "Reset", clearRoles ),
Text Box( " " ),
//Remove Button
Button Box( "Remove",
colListY << RemoveSelected;
colListV << RemoveSelected;
Button Box( "Recall",
clearRoles;
/* Restore any previous settings from the global variables */
Try(
colListY << Append( ::ycolRecall );
colListV << Append( ::vcolRecall );
//Help not implemented here, buttons are shown in UI
Button Box( "Help", notImplemented )
If(
VMeth == "Excluded Rows Holdback",
HP = .;
KF = .;,
VMeth == "Holdback",
HP = VmethodDlg["HP_input"];
KF = .;,
VMeth == "Kfold",
HP = .;
KF = VmethodDlg["KF_input"];,
VMeth == "Validation Column",
HP = .;
KF = .;
lvl = 0;
For( r = 10, r <= N Rows( dt ), r++,
If( Column( dt, Eval( Eval Expr( Expr( ValidCol[1] ) ) ) )[r] == 2,
lvl
response_col = Column( dt, Eval( Eval Expr( Expr( y_resp ) ) ) );
coltype = response_col << Get Modeling Type;
dt_results = dt_parms << Subset(
Output Table( "Output of " || dtp_name || " with " || Vmeth || " Validation" || " for " || dt_name ),
All rows,
Selected Columns Only( 0 )
If( VMeth == "Excluded Rows Holdback",
VMeth_Insert = "Validation Method(\!"Excluded Rows Holdback\!")";
If(
coltype == "Ordinal",
set = 1;
o_box = 3;
ncol_box_v = 10;
ncol_box_test = 19;
dt_results << New Column( "Generalized R² Training" );
dt_results << New Column( "Generalized R² Validation" );
dt_results << New Column( "Entropy R² Training" );
dt_results << New Column( "Entropy R² Validation" );
dt_results << New Column( "RMSE Training" );
dt_results << New Column( "RMSE Validation" );
dt_results << New Column( "Mean Abs Dev Training" );
dt_results << New Column( "Mean Abs Dev Validation" );
dt_results << New Column( "Misclassification Rate Training" );
dt_results << New Column( "Misclassification Rate Validation" );
dt_results << New Column( "-LogLiklihood Training" );
dt_results << New Column( "-LogLiklihood Validation" );
dt_results << New Column( "Sum Freq Training" );
dt_results << New Column( "Sum Freq Validation" );,
coltype == "Nominal",
set = 2;
o_box = 3;
ncol_box_v = 10;
ncol_box_test = 19;
coltype == "Continuous",
set = 3;
o_box = 3;
ncol_box_v = 2;
ncol_box_test = 3;
dt_results << New Column( "R² Training" );
dt_results << New Column( "R² Validation" );
//dt_results << New Column( "R² Test" );
//dt_results << New Column( "RMSE Test" );
//dt_results << New Column( "Mean Abs Dev Test" );
//dt_results << New Column( "-LogLiklihood Test" );
dt_results << New Column( "SSE Training" );
dt_results << New Column( "SSE Validation" );
//dt_results << New Column( "SSE Test" );
//dt_results << New Column( "Sum Freq Test" );
If( VMeth == "Holdback",
VMeth_Insert = "Validation Method(\!"Holdback\!", " || Char( HP ) || ")";
If(
set = 1;
o_box = 3;
ncol_box_v = 10;
ncol_box_test = 19;
set = 2;
o_box = 3;
ncol_box_v = 10;
ncol_box_test = 19;
set = 3;
o_box = 3;
ncol_box_v = 2;
ncol_box_test = 3;
If( VMeth == "Kfold",
VMeth_Insert = "Validation Method(\!"Kfold\!", " || Char( KF ) || ")";
If(
set = 1;
o_box = 3;
ncol_box_v = 10;
ncol_box_test = 19;
set = 2;
o_box = 3;
ncol_box_v = 10;
ncol_box_test = 19;
set = 3;
o_box = 3;
ncol_box_v = 2;
ncol_box_test = 3;
If( VMeth == "Validation Column" & lvl > 0,
VMeth_Insert = "Validation(" || ":" || validCol[1] || ")";
If(
set = 1;
o_box = 3;
ncol_box_v = 10;
ncol_box_test = 19;
dt_results << New Column( "Generalized R² Test" );
dt_results << New Column( "Entropy R² Test" );
dt_results << New Column( "Misclassification Rate Test" );
dt_results << New Column( "Sum Freq Test" );,
set = 2;
o_box = 3;
ncol_box_v = 10;
ncol_box_test = 19;
set = 3;
o_box = 3;
ncol_box_v = 2;
ncol_box_test = 3;
If( VMeth == "Validation Column" & lvl == 0,
If(
set = 1;
o_box = 3;
ncol_box_v = 10;
set = 2;
o_box = 3;
ncol_box_v = 10;
ncol_box_test = 19;
set = 3;
o_box = 3;
ncol_box_v = 2;
ncol_box_test = 3;
imax = N Row( dt_parms );
For( i = 1, i <= imax, i++,
Nlayer = dt_parms:N_Layers[i];
If( dt_results:N_Layers[i] == 1,
dt_results:N_TanH_2[i] = 0;
dt_results:N_Linear_2[i] = 0;
dt_results:N_Gauss_2[i] = 0;
If( dt_results:N_Layers[i] == 2,
dt_results:N_Boosts[i] = 0;
dt_results:Learn_Rate[i] = 0.1;
NTH1 = dt_results:N_TanH_1[i];
NTH2 = dt_results:N_TanH_2[i];
NL1 = dt_results:N_Linear_1[i];
NL2 = dt_results:N_Linear_2[i];
NG1 = dt_results:N_Gauss_1[i];
NG2 = dt_results:N_Gauss_2[i];
Nboosts = dt_results:N_Boosts[i];
LR = dt_results:Learn_Rate[i];
TCov = dt_results:T_Cov[i];
RFit = dt_results:Robust_Fit[i];
PMethod = dt_results:Penalty_Method[i];
Ntours = dt_results:N_Tours[i];
str = Eval Insert(
"report = (dt << Neural(
Y( response_col ),
X(
:OFA...22_c0_g2_i1.p1,
:OFA...47_c0_g1_i1.p1,
:OFA...73_c1_g1_i3.p1,
:OFA...72_c1_g1_i1.p1,
:OFA...5_c1_g2_i15.p1,
:OFA...78_c2_g1_i3.p1,
:OFA...51_c4_g1_i1.p1,
:OFA...38_c0_g1_i8.p1,
:OFA...19_c0_g1_i1.p1,
:OFA...22_c2_g1_i4.p1,
:OFA...27_c1_g3_i5.p1,
:OFA...82_c3_g2_i3.p1,
:OFA...11_c1_g1_i7.p1,
:OFA...50_c2_g4_i1.p3,
:OFA...18_c1_g1_i7.p1,
:OFA...66_c2_g1_i3.p1,
:OFA...85_c0_g1_i2.p1,
:OFA...99_c5_g1_i6.p1,
:OFA...03_c2_g1_i1.p1,
:SYM...24_c0_g1_i1.p1,
:SYM...75_c0_g2_i1.p1,
:SYM...42_c0_g1_i1.p1,
:SYM...04_c0_g1_i1.p1,
:SYM...97_c0_g1_i1.p1,
:SYM...13_c0_g1_i1.p1,
:SYM...66_c0_g1_i1.p1,
:SYM...72_c0_g6_i1.p1,
:SYM...13_c0_g1_i1.p1 2,
:SYM...33_c0_g1_i1.p1 3,
:SYM...43_c0_g1_i1.p1,
:SYM...51_c0_g1_i1.p1,
:SYM...65_c0_g1_i1.p1 2
^VMeth_insert^,
Informative Missing(0),
Transform Covariates(^TCov^),
Fit(
NTanH(^NTH1^),
NLinear(^NL1^),
NGaussian(^NG1^),
NTanH2(^NTH2^),
NLinear2(^NL2^),
NGaussian2(^NG2^),
Penalty Method(\!"PMethod\!"),
Number of Tours(^Ntours^),
N Boost(^Nboosts^),
Learning Rate(^LR^)
Go,
invisible
)) << Report;"
Eval( Parse( str ) );
w = Window( dt_name || " - " || "Neural of " || y_resp[1] );
T_stats = w[Outline Box( o_box ), Number Col Box( 1 )] << Get;
V_stats = w[Outline Box( o_box ), Number Col Box( ncol_box_v )] << Get;
Test_stats = w[Outline Box( o_box ), Number Col Box( ncol_box_test )] << Get
report << Close Window;
If( coltype == "Ordinal",
dt_results:Generalized R² Training[i] = T_stats[1];
dt_results:Entropy R² Training[i] = T_stats[2];
dt_results:RMSE Training[i] = T_stats[3];
dt_results:Mean Abs Dev Training[i] = T_stats[4];
dt_results:Misclassification Rate Training[i] = T_stats[5];
dt_results:Name( "-LogLiklihood Training" )[i] = T_stats[6];
dt_results:Sum Freq Training[i] = T_stats[7];
dt_results:Generalized R² Validation[i] = V_stats[1];
dt_results:Entropy R² Validation[i] = V_stats[2];
dt_results:RMSE Validation[i] = V_stats[3];
dt_results:Mean Abs Dev Validation[i] = V_stats[4];
dt_results:Misclassification Rate Validation[i] = V_stats[5];
dt_results:Name( "-LogLiklihood Validation" )[i] = V_stats[6];
dt_results:Sum Freq Validation[i] = V_stats[7];
dt_results:Generalized R² Test[i] = Test_stats[1];
dt_results:Entropy R² Test[i] = Test_stats[2];
dt_results:RMSE Test[i] = Test_stats[3];
dt_results:Mean Abs Dev Test[i] = Test_stats[4];
dt_results:Misclassification Rate Test[i] = Test_stats[5];
dt_results:Name( "-LogLiklihood Test" )[i] = Test_stats[6];
dt_results:Sum Freq Test[i] = Test_stats[7];
If( coltype == "Nominal",
If( coltype == "Continuous",
dt_results:R² Training[i] = T_stats[1];
dt_results:RMSE Training[i] = T_stats[2];
dt_results:Mean Abs Dev Training[i] = T_stats[3];
dt_results:Name( "-LogLiklihood Training" )[i] = T_stats[4];
dt_results:SSE Training[i] = T_stats[5];
dt_results:Sum Freq Training[i] = T_stats[6];
dt_results:R² Validation[i] = V_stats[1];
dt_results:RMSE Validation[i] = V_stats[2];
dt_results:Mean Abs Dev Validation[i] = V_stats[3];
dt_results:Name( "-LogLiklihood Validation" )[i] = V_stats[4];
dt_results:SSE Validation[i] = V_stats[5];
dt_results:Sum Freq Validation[i] = V_stats[6];
dt_results:R² Test[i] = Test_stats[1];
dt_results:RMSE Test[i] = Test_stats[2];
dt_results:Mean Abs Dev Test[i] = Test_stats[3];
dt_results:Name( "-LogLiklihood Test" )[i] = Test_stats[4];
dt_results:SSE Test[i] = Test_stats[5];
dt_results:Sum Freq Test[i] = Test_stats[6];
