Fit straight lines to multiple plotted charts and display equation
Created:
Oct 25, 2021 02:07 PM
| Last Modified: Jun 11, 2023 4:18 AM(3883 views)
I need to do a linear fit on my data plotted as multiple graphs similar to shown in the attached example. I am still learning JMP so do not know how to do linear fit on each plotted graph and display the equation on it. Any help is appreciated.
There should be a set of "icons" across the top (see red arrow). If you select the 3rd icon, that puts a best fit line through the data. Then it opens up options. Check the box next to equation (other red arrow)
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '430153' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '430153') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '430153') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
