bootstrapping
Am looking for a bootstrapping JMP script that allows bootstrapping without much additional scripting. If it doesn't exits it should.... The knowledge of bootstrapping is alot more common than scripting knowledge.
Re: bootstrapping
If you have JMP Pro, starting with version 10, there is a bootstrap option available in most platforms. To use it, you right-click on the statistics that you want to bootstrap and select Bootstrap from the context menu that comes up.
See the following blog post for more information:
Introducing the one-click bootstrap in JMP Pro
-Michael
Michael Crotty
Principal Statistical Writer
Manager, Statistical Documentation
JMP Development
Re: bootstrapping
Just curious, what statistics are you generating from bootstrapping?
Re: bootstrapping
quantiles and other distribution info
louv
Staff (Retired)
Re: bootstrapping
Check this out
http://web.utk.edu/~leon/stat201/One%20Sample%20Bootstrap%20Interval.html
Re: bootstrapping
-Michael
Michael Crotty
JMP Development
