KarlK
binary recoding
How can I simply recode a colum with numeric or missing values into a binary code?
I simply wanto to know, if there is any entry ("1") or none ("0").
For this purpose I would like to recode the colum by recoding "missing value" to "0" and any other numeric value to "1".
hcarr01
Re: binary recoding
Names Default To Here (1);
dt = current data table();
// Nouvelle colonne : TEST
dt << New Column( "TEST",
	Numeric,
	"Continuous",
	Format( "Best", 12 )
// Modifier la formule de colonne : TEST
dt:TEST << Set Formula(
	If( !Is Missing( :data ),
		:TEST = 1,
		:TEST = 0
Vous pouvez rechercher les valeurs manquantes de la BD suivante :
Re: binary recoding
Just using Not(IsMissing()) should be enough
dt = New Table("Untitled",
	Add Rows(5),
	Compress File When Saved(1),
	New Column("Column 1",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([., 2, ., 5, .])
dt << New Column("Check", Numeric, Nominal, Formula(
	!IsMissing(:Column 1)
And if you want to have then as characters wrap that with Char()
Char(!Is Missing(:Column 1))
hcarr01
Re: binary recoding
pouvez-vous donner un exemple ?
Re: binary recoding
I would use a simple script to do the change.
If you have a column of data that contains zeros and other values
You can use this simple script to change the values
For Each Row(
If( :Y == 0, :Y = 0, :Y = 1 )
hcarr01
Re: binary recoding
	Numeric,
	"Continuous",
		:TEST = 1,
		:TEST = 0
Re: binary recoding
	Add Rows(5),
		Numeric,
		"Continuous",
		Format("Best", 12),
