konradkk
basic JMP vs JMP Clinical
I got a question whether the basic JMP version has enough capability to analyse Adverse Events or only JMP Clinical would be the option?
Thank you,
Konrad
6 REPLIES 6
Re: basic JMP vs JMP Clinical
Hi @konradkk,
How were you looking to analyze Adverse Events? What is the structure of your data?
Best,
Chris
Chris Kirchberg, M.S.2
www.jmp.com
konradkk
Hi Chris,
at this point I am just waiting for the data but I would assume the structure would be a standard one. The analyzes would be more towards testing for differences in recent years vs past historical.
Thank you,
Konrad
Do you know if the data will delivered as a single file? What kinds of statistical analyses are you planning to perform? Specific visualizations you might want? Will you compare to other drugs as well?
Since you will be comparing to historical data, will you use the study name as the comarision (the model effect)?
Thanks,
Chris
www.jmp.com
konradkk
Hi Chris,
I don't know yet but I hope it is a single file. I was thinking to start with the Wilcoxon tests as to compare the annual AEs rates over time. At this time the idea is to just get an idea of the trend and if significant differences are happening. No other drugs or study name will be used.
Thank you,
Konrad
Hi Konrad,
Given this, I would say JMP would be fine for what you are looking to do.
Hope that helps.
Best,
Chris
www.jmp.com
konradkk
Thank you very much Chris,
Konrad
