AdamChoen
assigned spec limits from limits column
I have a data table with the following columns, how can I assign the limits to the value column as property?
meaning when I plot value by date ill see those limits automatically
I tried
:value << set property(
"spec limits",
{LSL( : LCL ) , USL( : UCL ), Target( : Target ), Show Limits( 1 )}
thanks!
Thanks, Adam
Re: assigned spec limits from limits column
Your example data table does not contain any columns named LSL or USL.  Assuming they do exist, but are just missing from the display your code remains with a couple of problems.  First, you are attempting to insert values into a list structure.
{LSL( : LSL ) , USL( : USL  ), Target( : Target ), Show Limits( 1 )}
Because this is a list, it will not parse and evaluate itself.
The second item, is that, Spec Limits is a column property, and therefore, only 1 set of Spec Limits can be set for your column :Value.  If you have a columns named :LSL, :Target and :USL, you will need to specify which row in the data table contains those limits.  Below is one method that can be used to add the Spec Limits.  In the code, I am assuming there are columns of :USL, :Target and :USL, and that row 5 contains the values you want to use.
Eval(
	Substitute(
			Expr(
					"spec limits",
					{LSL( __LSL__ ), USL( __USL__ ), Target( __Target__ ), Show Limits( 1 )}
		Expr( __LSL__ ), :LSL[5],
		Expr( __USL__ ), :USL[5],
		Expr( __Target__ ), :Target[5]
11 REPLIES 11
Eval(
	Substitute(
			Expr(
					"spec limits",
AdamChoen
Thanks for the solution for the original question.
I have another question regarding the same issue/example.
Can I create a smart column property or trend chart property so that when I create a trend chart using jsl the limits will be included.
I think there need to be something because I have value and limits in every row.
Thanks, Adam
markschahl
Show Limits(1) - I was searching around the scripting guide yesterday on how do this to a bunch of columns. Thanks!
AdamChoen
Not working for me,
Did you mean as in the example?
biv=Bivariate(
	Y( :VALUE ),
	X( :DATE ),
	By(
		:TEST
biv << Show Limits(1);
Thanks, Adam
markschahl
Adam:
My application was to be able to toggle the 'Show as graph reference lines' for Spec Limits. After doing Process Capability, loading spec limits from a table, then saving them to columm property I noticed that none of the columns had the 'Show as graph reference lines' checked. For 55 columns I did not want to do this manually (but I did - I searched the documentation but could find out how to do this). Now I have JSL that can do it. Change the (1) to a (0) to toggle. You want to see the Spec Limit lines for some plots, but not others.
mycols = dt << Get Column Names( string );
For( i = 2, i <= N Items( mycols ), i++,
Column( i ) << Set Property( "Spec Limits", {Show Limits(1)} );
So, this JSL will toggle the Show Limits(), but it will wipe out the LSL(), Target(), USL() assigned to the column.
Does anyone out there have a way to only toggle the Show Limits()?
Here is a simple script that will set the Show Limits without deleting the already set limits
dt = Open( "$SAMPLE_DATA\Semiconductor Capability.jmp" );
mycols = dt << Get Column Names( numeric, string );
For( i = 1, i <= N Items( mycols ), i++,
	spec = Column( dt, mycols[i] ) << Get Property( "Spec Limits" );
	If( Is Empty( spec ) == 0,
		LSL = Try( spec["LSL"], . );
		USL = Try( spec["USL"], . );
		Target = Try( spec["Target"], . );
		Eval(
			Substitute(
					Expr(
						Set Property(
							"Spec Limits",
				Expr( __LSL__ ), LSL,
				Expr( __USL__ ), USL,
				Expr( __Target__ ), Target
markschahl
Jim:
Thanks! I now owe you two beers :).
One of these days I will have to confromt my fear of Eval / Expr / Substitute
1 Single Malt Scotch == 2 Beers
markschahl
Gladly! Ever had Ardbeg Uigeadail? Are you coming to Discovery 2018 in Cary?
