arrange data and analyse
SampleRulesOx95
Hi
i have done a trial with four blocks. in each block, in modality column, i want to arrange the data to get the avergage of M1+M1 to get respective data of each treatment and then analyse it for differenrt treatments. can u help?
Re: arrange data and analyse
What is M1+M1?   Are you trying to imply that you want to average two levels of Modality and then redo the analysis?
i want to take average of two levels of M1+M1 into 1 value. i have four blocks and six modalities. so in total i want to get 24 values
Use the Summary platform to create a summary data table.  Specify Block and Modality as the grouping columns, and specify to generate the Average for the response columns
     Tables=>Summary
You can then run your Fit Model on the new data table.
How to copy data from there?
Copy the results from the Fit Model, or how to copy the data table after running the Summary?  And where are you copying it to?
