qt
qt
add fitting line using jmp script.
I am using jmp script to draw X-Y scatter plots.
Can I add fitting lines by group using JMP scripts too?
here is sample of the script I copied:
Bivariate(
    Y( :Height ),
    X( :Age ),
    Fit Where( :HDDt == "Schoo_A", Fit Line( {Line Color( {213, 72, 87} )} ) ),
    Fit Where( :HDDt == "School_B", Fit Line( {Line Color( {64, 111, 223} )} ) )
If next time, I have 3 groups, School_A, School_B, School_C, do I have to manually add the
3rd fitting line, and choose the colors? I am hoping JMP script can choose color based on # of groups.
Thanks,
Qian
ms
Super User (Alumni) ms
Re: add fitting line using jmp script.
Bivariate() can have an optional Group By() argument.
An example:
Open( "$SAMPLE_DATA/Big Class.jmp" ) <<
Bivariate( Y( :weight ), X( :height ), Group by( :sex ), Fit line() );
ms
An example:
xlin11
what if remove the Fit line? is there any way to remove fit line from the plot?
ms
In JMP 10 this syntax can be used to remove the first fitted line:
biv << (Curve[1] << Remove Fit);
