vritti
JSL Create Variability Chart from Tabulate table
Hi All
I have the following script for issue presentation only:
I can't understand what is wrong - why chart not displayed.
dt = Open( "$SAMPLE_DATA/Hurricanes.jmp" );
tdt = dt<<
Tabulate(
  Add Table(
  Column Table(
  Analysis Columns( :Atmospheric Pressure ),
  Statistics( N, Mean )
  Row Table( Grouping Columns( :Name, :Name( "Wind (Knots)" ) ) )
pivotTable = tdt << Make Into Data Table;
tbName = dt << get name() || " - Pivot Table";
pivotTable << set name( tbName );
Variability Chart(
  Y( :Name( "Mean(Atmospheric Pressure)" ) ),
  X( :Name( "Wind (Knots)" ), :Name ),
  Analysis Type( Name( "Choose best analysis (EMS REML Bayesian)" ) ),
  Process Variation( 0 ),
  Connect Cell Means( 1 ),
  Std Dev Chart( 0 ),
  Dispatch(
  {"Variability Chart for Mean(Atmospheric Pressure)"},
  "Variability Chart",
  FrameBox,
  {Grid Line Order( 5 ), Reference Line Order( 6 )}
pmroz
Re: JSL Create Variability Chart from Tabulate table
You need to make the pivot table the current data table.  The variability chart platform is trying to run from the hurricanes table instead.  This code works:
tdt = dt << Tabulate(
    Add Table(
        Column Table( Analysis Columns( :Atmospheric Pressure ), Statistics( N, Mean ) ),
tdt << close window;
current data table(pivottable);
Variability Chart(
    Std Dev Chart( 0 ),
        Dispatch(
            FrameBox,
