See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
add error in profiler
PYS
PYS
I am using JMP Pro 15 and have a DoE with 3 responses (2 continuous and 1 binary).
I fitted two linear mixed models for my continuous responses and a GLM (binomial distribution, logit link and firth correction because of separation issues).
I wanted to plot the results of my different models in a common profiler. I was able to save the prediction formula for each of the 3 models and the standard error formula for the LMM models. However, I couldn't find how to add the confidence intervals for my GLM model.
Any idea how to proceed?
Thanks !
Byron_JMP
Re: add error in profiler
Dave at Pega Analytics has a nice post on this:  http://www.pega-analytics.co.uk/blog/the-prediction-profilers-hidden-secret/
The general idea is that you save the forumula for the standard error for each response and then in the Graph>Profiler you select the prediction formulas and the PredSE columns to profile.
PYS
PYS
thanks for the answer.
This is what I did for the LMM models but I have not found the standard error formula in the GLM model. Is it available?
