Is there a way to use a column format to make an integer value be zero padded? I know you can make a new formula and use right(:col, 5, "0") to get zero padding but it creates a new column that is a character Data type. In excel, you can use a format of "00000" to get zero padding up to five digits (to match the right() example above).
