th20180
Zero on log scale y-axis?
I applied overlay plot in JMP. My data ranges from 0 to 15990. I tried to plot my y-axis in log scale (not log-transform my data). Is there any way to set the minimum value of y-axis as zero? Thank you.
ron_horne
Re: Zero on log scale y-axis?
Hi th20180​,
PMroz​  is correct by deffinition. Yet, there is a plumbers solution of changing zero values to something very small (0.00000001 for example) and then you will get all the values in the graph. Once more, this is not considered scientifically rigorous.
best,
ron
pmroz
Zero is undefined in the log scale.
ron_horne
Hi th20180​,
best,
ron
