Created:
Sep 8, 2022 01:09 PM
| Last Modified: Jun 27, 2023 12:06 PM(5881 views)
| Posted in reply to message from txnelson 09-08-2022
Many thanks for the workaround.
I have this problem quite often. It's surprising that there is no easier solution (yet). -> I hope that the team from jmp can add an option to use separate entries on the different axes. If anybody else is also interested ... I just sent my wish:
I really hope, that in a future version there will be an option to shrink the information on the X Axis to the values that are needed for the respective plots.
For 2 or 3 main groups, the approach of @txnelson works. But if there are more main groups, the table gets wider and wieder.
I agree to @SamGardner - then one should nest the data on the X axis.
