Mickyboy
Wild card for Match function
Hi Everyone,
I had a variable "medium" and l needed a grouping variable so i created another variable for the grouping "EMEM Medium" and below if the code i used to populate the new variable.
Match( :Medium,
	"Standard", "Standard",
	"Standard 1", "Standard",
	"Standard 2", "Standard",
	"Standard 3", "Standard",
	"Standard 4", "Standard",
	"Standard 5", "Standard",
	"Standard 6", "Standard",
	"Sigma", "Sigma",
	"Sigma 1", "Sigma",
	"Sigma 2", "Sigma",
	"Sigma 3", "Sigma",
	"Sigma 4", "Sigma",
	"Sigma 5", "Sigma",
	"Sigma 6", "Sigma",
         "else", -9999)
just wondering if there is wildcard l could have used, or a different approach, to make the syntax a little more compact and readable.
Thanks
Mick
Georg
Re: Wild card for Match function
I think it's not possible with match, see:
Match (jmp.com)
But you can uses word in this case, it's much simpler:
dt = New Table( "test",
	New Column( "Medium","Character",
		set values(
			{"Standard", "Standard 1", "Standard 2", "Standard 3", "Standard 4", "Standard 5", "Standard 6", "Sigma", "Sigma 1", "Sigma 2", "Sigma 3",
			"Sigma 4", "Sigma 5", "Sigma 6"}
dt << New Column( "Match", "Character",
	formula(
		Match( :Medium,
			"Sigma", "Sigma",
			"Sigma 1", "Sigma",
			"Sigma 2", "Sigma",
			"Sigma 3", "Sigma",
			"Sigma 4", "Sigma",
			"Sigma 5", "Sigma",
			"Sigma 6", "Sigma",
			"else", -9999
dt << New Column( "Word", "Character",
	formula(
word(1, :Medium)
Georg
Georg
Match (jmp.com)
		set values(
	formula(
		Match( :Medium,
			"Sigma", "Sigma",
			"Sigma 1", "Sigma",
			"Sigma 2", "Sigma",
			"Sigma 3", "Sigma",
			"Sigma 4", "Sigma",
			"Sigma 5", "Sigma",
			"Sigma 6", "Sigma",
			"else", -9999
	formula(
word(1, :Medium)
Georg
JMP can also create the Word column shown by @Georg interactively (might need some additional handling for non-matches).
Right click on column header and create new formula column:
or use recode:
Mickyboy
Brilliant, thank you Georg, also thank you to jthi, appreciate the replies, thank you both
