  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
shampton82
Why is this code selecting the top level outline box and not the requested one?
I was playing along with a Discovery Summit video on interacting with Report layer objects and came to a crashing halt on my very first example I tired.
Here I am trying to select the Correlation outline box but this ends up selecting the entire Multivariate analysis.  I've tried a couple of different approaches and can't get it work out so humbling asking for some input!
dt=Open( "$SAMPLE_DATA/Big Class.jmp" );
dt<<Multivariate(
	Y( :height, :weight ),
	Variance Estimation( "Row-wise" ),
	Scatterplot Matrix( 1 )
obj=Current Report()["Multivariate"]<< get scriptable object;
obj<< XPath("//OutlineBox[text()='Correlations']")<<select;
Want this:
Getting this:
Steve
Level XIII
Re: Why is this code selecting the top level outline box and not the requested one?
You got it right, but your attempt to double-check was misleading : )
To select the outline boxes which are returned by the Xpath command, use:
(obj<< XPath("//OutlineBox[text()='Correlations']"))<<select;
Without the  additional brackets, you will send the select command to obj.
like in
Data Table( "Height" ) << Clear Select << Select Rows( [4] ) << Delete Rows;
Level XIII
like in
shampton82
Oh I was so close!!  Thanks for the assist @hogi , that was going to drive me crazy.....
Back to the video now
I Can See It. How Do I Get It? - JMP User Community
Steve
Level XIII
Great Video, thanks for the link!
