Jackie_
Why does the new window layout look different in JMP 19 compared to JMP 18?
Upgraded from JMP 18 to JMP 19, and I noticed that the same custom window looks quite different between the two versions. In JMP 19, there seems to be a lot of extra spacing between elements, making the layout appear more spread out, whereas in JMP 18, the components are more compact and aligned.
Is there a way to control or reduce the extra spacing so the layout looks similar to JMP 18?
Re: Why does the new window layout look different in JMP 19 compared to JMP 18?
JMP19 did change how JMP (and the display boxes) look like and in some cases they did add more spacing, so maybe some default padding values were changed? You might for example be able to use negative padding (not sure if it is really supported or if it is a bug). Also, there might have been some default font size changes.
