See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Why does JMP Not calculate STDEV correct
MikeDereviankin
JMP is over estimating the STDEV. In R/Excel this number is less than the mean. Why is JMP calculating these over estimations?
M. Dereviankin
Re: Why does JMP Not calculate STDEV correct
I think you will need to provide more details. JMP does indeed correctly calculate a standard deviation. So, a few questions:
* What version of JMP are you using?
* Can you share some of your data, even if it is anonymized? You may have your data formatted in an unusual way.
* How much data do you have for each of these categories?
* Have you verified these exact same calculations with this exact same data in R or Excel?
Remember that there is no requirement that a standard deviation be less than a mean. For skewed distributions, the standard deviation could certainly be larger than the mean.
Dan Obermiller
Using JMP 16 Pro.
I've attached some data where you can calculate the standard deviation per the 3 factors above (Gender, Age, Ethnicity) for each Congener. You'll notice that this calculation will indeed deviate if you run it with R. Even when analyzing these distributions or doing a normalization technique (log normalization), you'll note that the standard deviations are still completely off.
Attached is the data and a summary table I generated in R. JMP cannot replicate these calculations.
M. Dereviankin
Are you using a script like this?
Data Table( "NHANES 2003-2004" ) << Summary(
    Group( :Gender, :Age, :Ethnicity, :Congener ),
    Mean( :Lipid Weight ),
    Std Dev( :Lipid Weight ),
    Freq( "None" ),
    Weight( "None" )
The largest difference seems to agree to the resolution of the CSV numbers.
Georg
Dear @MikeDereviankin ,
I cannot reproduce the problem.
When importing your data into JMP (JMP Pro 16.1, Win10), I get exactly the same numbers (see Tabulate left) than you posted in your Summary (Summary Table right).
Perhaps there is an issue with importing the data?
Georg
The CSV data is helpful, but the issue could be how you have your JMP table formatted. Could you attach your JMP file??
Dan Obermiller
Byron_JMP
Change Gender Age and Ethnicity to Nominal (not continuous)
I ran tabulate just like you did in your first post, and made a data table from it.
Then I used tables>compare on my table and your summary.csv
The tables are identical
coding data correctly is very important
