Why can I not see the edit bar/analyze option
I am unable to edit any data table. It does not show the edit bar at the top so therefore I cannot create graphs/ use the analyze tab
Re: Why can I not see the edit bar/analyze option
What JMP version are you using?
In JMP 15 and earlier, the pull down menus were minimized behind either a bar across the top of the display window, or else a bar with three dots on it.  When the bar is clicked on, the pull down menus appear.
MRB3855
@SymetricFrog342  and @txnelson , I seem to remember that there is an option in preferences to hide it or not? Or am I making that up?
@SymetricFrog342 If you are on Windows, navigate in JMP to File -> Preferences -> Windows Specific and check the settings for Auto-hide menu and toolbar if this is set to Always or Based on Windows Size. If you change the setting to Never the menu is always present.
Screen capture from JMP 16.2:
Otherwise open a Tech Support case by emailing the issue to support@jmp.com
