Why JMP Neural Networks Don't Need Data Normalization
Created:
Feb 8, 2022 01:52 AM
| Last Modified: Jun 10, 2023 1:48 PM(3667 views)
When the data value vary widely, the data standardization process must be done first. Why does the JMP neural network do not need data standardization process?
i use JMP16 and read the PDF your give me before, i can not understand why don't need to normalization or do Johnson transformation but we get the model that fit new data.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '459043' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '459043') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '459043') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
