aprilmayjune
Where is 'Save Columns'?
Hi JMP experts,
I'm having a hard time finding 'Save Columns'.
I was told to do 'red triangle > Save Columns > Prediction Formula'.
I clicked all the red triangles that I see on my screen, but no luck in finding Save Columns. I also looked up Google..
Can anyone please help me find 'Save Colums' in JMP? I'm a newbie so any advice/feedback would be highly appreciated. Thank you in advance!
Re: Where is 'Save Columns'?
The
I selected from the analysis display output, not from the data table.  The results of the Save Columns will written to your data table
This command is available in the platform menu, not the data table. You first select a modeling technique in the Analyze menu, fit the data, select the model, then follow those intructions.
aprilmayjune
Forgot to mention that I have created an empty column called 'Prediction'
The
