hogi
Level XIII
Where Ctrl+Z / Undo will help
More and more steps in Jmp can be undone via Ctrl-Z.
But some actions are not yet recorded.
Let's collect what could be improved ...
[More Topic Containers like this]
hogi
Level XIII
Re: Where Ctrl+Z / Undo will help
Hm, let's also list some - the best - positive examples.
Like Deletion of a table script - how good that I can recover the script via Undo !
hogi
Level XIII
what can not be undone:
1) removal of a local data filter
Sometimes - stupid me - I think: Oh, let's add a data filter.
and after clicking on the toolbar icon:
I realize:  there was already one - and I just removed it.
Another example: In Dashboards.
The toolbar icon just adds the filter to the first plot in the dashboard.
... or it removed it from the first plot - even if your actual intention was to add a local data filter to the second plot ...
Note: It would be helpful if the toolbar icon had 2 different colors - one for adding a filter and one for removing it (if the filter is already there).
hogi
Level XIII
Most of the changes in a GraphBuilder Platform can be undone via Ctrl-Z.
wonderful!
How does the plot look like with "age" used as X Group - oh no - Ctrl Z.
Let's drag a second column onto the X axis to show a hierarchy - oh no - Ctrl Z.
How do the points look like with another color - oh - Ctrl Z.
hogi
Level XIII
2) Changed axis settings.
You just removed the wrong reference line? no chance to add it again.
You just changed the scale type from Normal Probability to Linear? You have to go there again to change it back
You changed the range of an axis - either via the menu or via dragging the axis? Hm, you have to manually find the old value *)
*) Most likely the ticks changed from 1 week to 2 months. or from 1 step to 5 steps. So check them as well ...
hogi
Level XIII
3) recode of multiple columns via Cols/Standardize Attributes/Recode
