When I choose to display the limits as reference lines, two labels are automatically added to the graph, which hide the original values.How can I show the labels and values ?
Re: When I choose to display the limits as reference lines, two labels are automatically added to the graph, which hide the original values.How can I show the labels and values ?
If you go into the Axis Settings for the X axis, you can Update the reference lines, and remove the labels
Thanks sir, now I can edit the labels like that, but I made lots of graghs,Is there a way to modify them all?
The only way that I can think of how to handle this across a large number of plots, is to use JSL to add the reference lines rather than using the automated spec limits display.
Victor_G
Hi @ClassSpacesOx28,
If you right-click in the axis of the graph that shows the labels and select "Axis Settings", you will have hte option to customize the reference lines :
Select the reference line you want to change, remove the label and update the settings, this will clear the label on the graph and will keep the original values instead :
Victor GUILLER
