vince_faller
What is the valid range of random seed?
In this case for DOE but I hope it's always the same range.
Vince Faller - Predictum
jules
Re: What is the valid range of random seed?
Hi @vince_faller,
At first, I thought it would be something on the order of 1 to (2^19937)-1, because that's the period of the Mersenne Twister generator JMP uses. But, though some trial and error I discovered it seems to be somewhere in the neighborhood of 1 to a 64bit integer. Below is a script where I fit two neural models with the seed set, and around 9,223,372,036,854,775,295 is where I cross over to the seed not actually being set (i.e., the models don't match since the holdout sets differ). Interestingly it's not always right at 9223372036854775295 that things break down. Sometimes it's 9223372036854775295+1, sometimes it's 9223372036854775295 + 1000. I'm confused by that, and I'm sorry I don't have an explanation for why; hopefully, someone else will!
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
seed = 9223372036854775295; //works, i.e., same results for validation
//seed = 9223372036854775295 + 1000; //does not work
Neural(
	Y( :sex ), X( :height, :weight ),
	Informative Missing( 0 ),
	Validation Method( "Holdback", 0.3333 ),
	Set Random Seed( seed ),
	Fit( NTanH( 3 ) )
Neural(
	Fit( NTanH( 3 ) )
I hope this helps a bit!
@jules
Craige_Hales
It looks like the internal generator uses integers from 1 to (2^32)-1 for the reset value.
Craige
jules
Hi @vince_faller,
Neural(
	Fit( NTanH( 3 ) )
Neural(
	Fit( NTanH( 3 ) )
@jules
Craige_Hales
Craige
