What is the difference between log and log10 transformation in JMP?
Sep 9, 2019 07:05 AM(27982 views)
Does someone know what the difference is between the log and log10 transformation in JMP? I cannot find any information on it... I discovered that they do not give the same result and I wonder what the reason is.
