mintkoko77
What is different the result between effect tests table and effect leverage plot
I got the result of the parameter estimates & the effect test table by fit model.
I used 5 factors and wanted to look the plot of each effect leverage.
It is differernt the result value(estimates value, F-ratio, p-value) between two table and effect leverage.
What is the reason?
Phil_Kay
Re: What is different the result between effect tests table and effect leverage plot
I looks like you have saved the leverage pairs for the effects from the model and then used Fit Y by X to plot the Y leverage vs X leverage. And then fit a mean and a regression line. Can you let us know more about why you have taken this approach? What were you hoping to understand by doing this?
Regards,
Phil
