mpatpc
What do the red and yellow numbers mean in the fixed effect tests
I ran the fit group analysis.
I am looking at the fixed effect test report and I wanted to know if the yellow prob > F values show a positive correlation  meaning the higher the value the more positive the effect and the red prob >F values indicate a negative correlation meaning the lower the value the better the result.
jules
Re: What do the red and yellow numbers mean in the fixed effect tests
Hi mpatpc,
The coloring on p-values, conditional formatting as it's called in JMP, is based on how small the p-value is. By default, P-values are colored red if they are between 0.01 and 0.05, and p-values are colored yellow if they are less than 0.01.
For platforms that support correlation (such as Analyze > Multivariate) conditional formatting is applied to values on the basis of the degree and direction of correlation.
I hope this helps!
Julian
jules
Hi mpatpc,
I hope this helps!
Julian
