Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
eddyruijter
Westgard rules 2s and 3s
Hi JMPusers,
Using the control chart builder and Westgard rules (JMP16), the chart displays a 2s warning when a data point has a 3s violation. When I remove the 2s rule, the chart displays the 3s violation for the data point. This order seems not logical to me; when there is a 3s violation it is automatically also a 2s violation but when I see the 2s violation displayed it is not clear if it is also a 3s violation. Of course a 3s violation is more severe and you don't want to miss that information.
Is there any solution to change the order of displaying; a 3s when applicable and the 2s if no 3s violation but only a 2s violation?
Is a report possible for all violations for all points in the data file?
kind regards,
Eddy
Re: Westgard rules 2s and 3s
I'm not sure if there is any way of changing the order, but scripting and using Alarm Script might be able to do what you want (might not be the easiest script though)
