See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
Weighted Standard Deviation
fanienel
Hi
How does JMP calculate a weighted standard deviation (when a variable is  selected in the weighting tab in the Distribution Platform?
Thank you
Fanie
Re: Weighted Standard Deviation
It is not a matter of ignorance. There are at least four definitions of the weight standard deviation or variance. The definitions differ only in the denominator that is used. That is to say that the weighted mean and weight sum of squares are the same in all the definitions. JMP only implements one of the four definitions. Other software might implement this definition or one of the others.
The calculation is described here: weighted arithmetic mean. Use these formulas to understand the quantities in the results.
Use the script to illustrated the calculation steps. Open the Log before running the scripts.
Names Default to Here( 1 );
// open examle
dt << New Column( "Row Weight", Numeric, Continuous,
	Values(
		[0.466037725564092, 3.88878780649975, 2.4091640743427, 2.11785415420309,
		4.79403748759069, 2.30050488375127, 1.58066931064241, 3.18035316769965,
		1.57862229505554, 0.304837201256305, 3.91091752331704, 2.63118736562319,
		3.27893625595607, 3.02616479573771, 1.75871466752142, 1.95901472005062,
		1.4666282152757, 2.11275573237799, 2.02008433057927, 4.89492299617268,
		0.493469994980842, 4.89886545110494, 2.22502982476726, 4.72375275800005,
		0.830245516262948, 1.67820788919926, 3.44848407898098, 4.0259948768653,
		3.2834971731063, 4.52901363372803, 3.88477634754963, 4.72076337435283,
		4.64333190233447, 3.1073961337097, 0.579181439243257, 2.74820194579661,
		0.191317443968728, 2.94498334173113, 2.51307534286752, 1.23225981369615]
// launch distribution analysis
biv = dt << Distribution(
	Weight( :row weight ),
	Continuous Distribution(
		Column( :height ),
		Customize Summary Statistics(
			Sum Wgt( 1 ),
			Variance( 1 ),
			Corrected SS( 1 ),
			Set Alpha Level( 0.05 )
		Dispatch( {}, "height", OutlineBox, {Set Title( "weighted height" )} )
// compute weight standard deviation and show intermediate results
y = :height << Get As Matrix;		// data
w = :row weight << Get As Matrix;	// weights
n = Sum( w );						// sum of weights
wYBar = (w`*y / n)[1];				// weighted average
ss = (w`*(y-wYBar)^2)[1];			// corrected weighted sum of squares
var = ss / (N Row( y )-1);			// weighted variance, unbiased
s = Sqrt( var );					// weighted standard deviation
Show(  wYbar, s, ss, var );			// view all results in Log
fanienel
HI Mark,
Thank you,  I do appreciate your  input.
So, I assume then the  standard deviation printed in the distribution platform  when a weight column  property  has  been set should not be used?
Why do you assume that you should not use it?
fanienel
Hi Mark,
I am drowning in my own ignorance...
I  calculated  the weighted mean of a dataset in Excel and compared it to JMP. The results did not match.
The formula I used in is:
This agrees with the code except:
should be:
var = ss / ((N Row( y )-1/N Row(y))*n;			// weighted variance, unbiased
Clearly I do not understand  this.
Thank you
Fanie
