samsam
Want to check each numeric column for each row of test and then assign a value (yes or No)
I want to go through each row in this table for compare value 1 thru value 8, and if one value is less than 1 and any other remaining value is greater than 1, then i say yes or no in the result column. How do i do that?
IDvalue 1value 2value 3value 4value 5value 6value 7value 8Result
32001105030.0640640000000Yes
32001105200.0578640000000No
32001105460.069850000000
320011056200.064931000000
32001105970.062410000000
Re: Want to check each numeric column for each row of test and then assign a value (yes or No)
In you example data table, all data are less than 1, there are no numeric data greater than 1, so the algorithm you have described could never happen. I assume that either the example data table is in error, or your description of what you are looking for is not correct.
You show that row 1 should result in a Yes, and row 2 in a No, but they are identical in data pattern. All values are less than 1 and no values are greater than 1.
I am sure that I am missing something.
samsam
My table is long and there are some columns for each row that has value greater than 0 and less than 1. Then next column for the same row is greater than 1.
So I want my logic as follow:
1. Check each column to see the values are greater than 0 and less than 1.
2. Second, check each column again to see if the values are greater than 1.
3. Third, if there are two columns, one represent between 0 and 1 and any other column that represents greater than 1, I fill in the result column as true.
Please let me know if that makes sense.
Thierry_S
When you are referring to "one value is less than 1" do you mean less than the numerical value = 1 or are you referring to the value of Column 1? Assuming the latter, it is still difficult to grasp the logic behind the results you shared for row 1 and row 2 as @txnelson mentioned
Please, help us help you.
Best,
TS
Thierry R. Sornasse
samsam
D value 1 value 2 value 3 value 4 value 5 value 6 value 7 value 8 Result
3200110503 0.064064 0 0 0 0 0 1.5 0 Yes
3200110520 0.057864 0 0 0 0 0 0 0 No
3200110546 0.06985 0 0 0 0 0 0 2.6 Yes
3200110562 0 0.064931 0 0 0 0 0 0
3200110597 0.06241 0 0 0 0 0 0 0
I am referring to check each column for each row to look for two conditions:
1. Check each column to identify any column has value greater than 0 and less than1.
2. Check each column again to identify if any column has value greater than 1.
3. If statement 1 and statement 2 is true for any row, then i report value Yes. If false, then i report value No.
Thanks again for helping.
Here is a hardcoded straight forward piece of formula that will create the results you want, given your latest description
If(
	(:value 1 > 0 & :value 1 < 1 | :value 2 > 0 & :value 2 < 1 | :value 3 > 0 &
	:value 3 < 1 | :value 4 > 0 & :value 4 < 1 | :value 5 > 0 & :value 5 < 1 |
	:value 6 > 0 & :value 6 < 1 | :value 7 > 0 & :value 7 < 1 | :value 8 > 0 &
	:value 8 < 1) & Max(
		:value 1,
		:value 2,
		:value 3,
		:value 4,
		:value 5,
		:value 6,
		:value 7,
		:value 8
	) > 1,
	"Yes",
	"No"
