klkriech
Variable column group name for 'Group Columns()'
Hi all,
I'm trying to select columns based on a list of strings, and dump the columns into a group also based on the list.
Here's the code I'm using:
// phase names by which we want to group groupnames = {"Centering", "Dwell", "Capture", "Locking"}; // all column names in the table allcols = dt << Get Column Names(); For( i = 1, i <= N Items( groupnames ), i++, curgroup = {}; dt << Clear Column Selection; // get all cols with the phase name For( j = 1, j <= N Items( allcols ), j++, If( Contains( allcols[j], groupnames[i] ), As Column( allcols[j] ) << Set Selected( 1 ); //Insert Into(curgroup, allcols[j]); ); ); // make a new group from these columns //dt << Group Columns(char(groupnames[i]), curgroup); dt << Group Columns( groupnames[i] ); );
I get the error "JMP cannot determine the columns to be grouped from the given script."
If I change the last line to something like dt << Group Columns ( "fixed string") it will work (but they'll all be in the same group).  I'm not sure what I'm doing wrong.  groupnames[i] should be a string (right?), which is the expected input for Group Columns().
Thanks,
Kristo
cwillden
Re: Variable column group name for 'Group Columns()'
Sometimes, JMP is weird about evaluating variables that should resolve to the expected argument type.  I generally try not to do this, but you can usually get around these issues with a Eval-Parse-Eval Insert sequence.  This always feels like a bit of a hack, but it's like duct tape with JSL.
dt = Current Data Table();// phase names by which we want to group
	curgroup = {};
		If( Contains( allcols[j], groupnames[i] ) > 0,
	Eval(Parse(Eval Insert("\[dt << Group Columns( "^groupnames[i]^", curgroup )]\")));
-- Cameron Willden
cwillden
	curgroup = {};
-- Cameron Willden
klkriech
Thanks, that did it!  Any pointer to documentation on the what the different escape sequences are for?  The "help" for Parse() is not so useful.
cwillden
Eval Insert() evaluates variables within a string. The variables in the string are wrapped in “^” characters. Parse() turns a string into an expression. Eval() evaluates the expression.
So basically you build the expression as a string with the variable values resolved within the string, you parse the string into an expression, and evaluate the expression.
-- Cameron Willden
Here is how to get to the documentation on the escape characters.  Go to
     Help==>Books==>Scripting Guide
and then do a page search for
It will take you directly to the table of escape characters
klkriech
Thanks again.  I was just looking in the html documentation, not the books.
