Rozenzwaige2
Variable View
In SPSS there is a window called "Variable View". this is a table that displays information about the variables in the data in one place.
Is there something similar in JMP Pro?
Re: Variable View
To my knowledge JMP doesn't offer similar view by default, but maybe this add-in  by @Justin_Chilton might get fairly close.
Rozenzwaige2
Re: Variable View
Thank you!
Re: Variable View
The number of, and complexity of Column Properties in JMP is far more extensive than SPSS.  Therefore, JMP uses it's Column Viewer, Column Info and Standardize Attributes to display and manage them.  I suggest you first take a look at the Column Info environment to get a flavor for the items that are available and how they can be compared between columns.
     Select the columns of interest, and then go to
          Cols=>Column Info....
