Hauskov
Using variables i JSL
Hi
I'm new to jsl but have a hard time understanding how it deals with variables. In the example below I define an LSL and alpha-value. It seems arbitrary to me, when jmp will use the defined variables and when it won't.
  • It has no problem using myLSL in Process Capability
  • It wont use myAlpha under Tolerance Interval. Instead, it will use the default value (but does not throw an error saying e.g. that the variable is unknown). If I put in a value directly, it works, but I want to be able to define a variable that I can then reference throughout the script.
Can someone help explain this to a novice jsl user? Or provide a relevant reference. Thank you!
myLSL = 2.1; myAlpha = 0.8;
// Distribution and Tolerance Interval
Current Data Table(dt);
Distribution(
	Continuous Distribution(
		Column("ColumnName"),
		Fit Distribution( Normal( Spec Limits( LSL( myLSL ) ) ) ),
		Process Capability( LSL( myLSL ), Target( . ), USL( . ) ),
		Tolerance Interval(
			Alpha( myAlpha ),
			Proportion( 0.90 ),
			Lower,
			Parametric Normal
Re: Using variables i JSL
There remains inconsistencies in whether arguments can be variables or they must be literals. The Alpha() argument takes a literal argument. So you must substitute the value in the variable into the expression to make it literal.
Names Default to Here( 1 );
// example data set
myLSL = 50; myAlpha = 0.8;
dist = dt << Distribution(
		Column( :height ),
		Fit Normal( Process Capability( LSL( myLSL ), Target( . ), USL( . ) ) )
Eval(
	Substitute(
		Expr(
			dist << Tolerance Interval(
				Alpha( aaa ),
				Proportion( 0.9 ),
				Lower,
				Parametric Normal
		Expr( aaa ), myAlpha
@Audrey_Shull
Thank you for reporting this issue. JMP still has some inconsistencies regarding evaluation of JSL variables. However I can confirm that, in our next available release of JMP 16.1, the tolerance interval for Process capability will evaluate a variable for the alpha argument.
