anne_sa
Using several characters as delimiter for the Words function
Hello everyone,
I would like to know if it is possible to use a string with several characters as a delimiter for the Words function.
Here is a dummy example:
When I type :
words("Test1eeTest2","ee")
I would like to get:
{"Test1","Test2"}
Instead of:
{"T”,”st1","T”,”st2"}
Is there a way to get that?
Thanks in advance for your help.
Best regards,
Craige_Hales
Re: Using several characters as delimiter for the Words function
You could use regex to change the ee to another single character.  If you think @ does not occur in the data,
words(regex("Test1eeTest2eeTest3eeTest4","ee","@",GLOBALREPLACE),"@")
{"Test1", "Test2", "Test3", "Test4"}
If you are not sure about @ but are pretty sure the ASCII Unit Separator character does not occur, you could use
words(regex("Test1eeTest2","ee","\!U001F",GLOBALREPLACE),"\!U001F")
The Unit Separator is unlikely to be in your data:
the US is really a single character in spite of appearances.  Your font may show it differently, or not at all.
Craige
8 REPLIES 8
Craige_Hales
Craige
anne_sa
That's work perfectly !
Thank you so much for your fast answer Craige@JMP.
Jeff_Perkinson
Craige@JMP beat me to the punch with the general technique, but I'll put a plug in for the Substitute() function which I find more readable than the regular expressions. It's up to you which you choose to use.
words(substitute("Test1eeTest2", "ee", "!"),"!")
{"Test1", "Test2"}
-Jeff
pmroz
One advantage of regex is you can make it case-insensitive with the IGNORECASE argument.
words(regex("Test1eeTest2eeTest3EETest4","ee","@", IGNORECASE, GLOBALREPLACE),"@");
Craige_Hales
Substitute might be a lot better, depending who will maintain the JSL later!
Craige
anne_sa
Thanks to all of you for sharing your advices and points of view!
Except the fact that regex can be case-insentitive, could you please tell me what is the difference between the two functions?
Craige_Hales
The two functions barely overlap.  Regex only works with text, and can use very complicated patterns.  Substitute only works with very simple patterns, and can operate on text, lists, and expressions.
Regular Expressions
Character Functions
JSL Character String Functions
Craige
anne_sa
Alright thank you for these details Craige@JMP!
