ehchandlerjr
Using script to reference another script gives error where running only second script works just fine.
Hello - I am working on two scripts, one where I make a user input box, and a second where I import an XML file. I built the XML file importer as a standalone script, and it works just fine. However, when I call it with the button script, I can't get it to work, saying
Wrong result type for expression for column xsi:Schema Location 1 at row 1 in access or evaluation of 'Set Each Value' , Set Each Value( schemaLoc1 ) /*###*/ at line 1012 in jmpprj://contents/Import XRD XML.jsl
At line 982, the "schemaLoc1" doesn't seem to be picking anything up, which is why the 1012 line isn't working, but I'm not sure why calling the script from a button would mess it up unless my assignment of dt to the current data table changes, as I have the button script as a table script, while the other is just sitting in the project folder, but I can't use "show" to see what dt is for some reason.
Also, for the button code, I've found a few forum posts, but they don't seem to work: How do you get Number Edit Box() to return the user input when its contained in a new window command (line 7)? I've tried making it equal to a variable like the scripting guide and forum posts say, but that seems to just return  b1 = DisplayBox[NumberEditBox]; and not a value.
Edward Hamer Chandler, Jr.
Re: Using script to reference another script gives error where running only second script works just fine.
Depending on how you want to get the value, either use << get inside button box or sometimes you might have to use << Set Number Changed . Below is example from Scripting Index using << Get
New Window("Example", numbox = Number Edit Box(0));
Print(numbox << Get);
ehchandlerjr
Just for posterities sake, the solution to the first question is that
1. I had been updating a version of the script that was apparently saved separately from the version stored in my JMP Project file (and my button code was referencing the project one), so I had to start editing the project one,
2. An annoying mundane error: I had a column reference without the row specified, e.g.
x = dt:Column1
instead of
x = dt:Column1[1]
Hope this helps someone think about the small details.
ehchandlerjr
That did it! Had a little trouble with demonstrating with Show() that the variable changed, but once I included it in the New Window command, it worked fine.
Thanks a bunch!
Most likely there should be no need to use Current Data Table() at all as open() will return the reference to your table.
ehchandlerjr
x = dt:Column1
instead of
x = dt:Column1[1]
