Here is some code that accomplishes what you want, but it isn't very pretty. What you want is to be able to do code generation with substitution, and that isn't handled very well in JMP.
dt = Open( "$SAMPLE_DATA\semiconductor capability.jmp" );
myfunc = Function( {},
return =
"\[Dispatch(
"2",
ScaleBox,
{Min( 92.9916666666667 ), Max( 127 ), Inc( 5 ), Minor Ticks( 1 ),
Add Ref Line( 118.356215277778, "Solid", "Black", "", 1 )}
Eval(
Substitute(
Expr(
Bivariate( Y( :NPN1 ), X( :PNP1 ), SendToReport( __dispatch__ ) )
Expr( __dispatch__ ), Parse( myfunc )
JMP can handle replacement of components within the platform structure, such as passing in a minimum value.
mymin = 80;
Bivariate(
Y( :NPN1 ),
X( :PNP1 ),
Dispatch(
"2",
ScaleBox,
{Min( Eval( mymin ) ), Max( 127 ), Inc( 5 ), Minor Ticks( 1 ),
Or what I believe is the prefered method, which is to generate the default graph, and then set the parameters after the generation, where a call to a function could be used to conditionally set the items desired;
myfunc = function({},
Report( biv )[Axis Box( 1 )] << Min( 80 );
biv = Bivariate(
Y( :NPN1 ),
X( :PNP1 ),
Dispatch(
"2",
ScaleBox,
myfunc;
