DSchweitzer
Using a list of column names in a varability chart
When creating multiple variability graphs, JMP generates a script example similar to the code below that includes the multiple Y Response columns as a comma separated list.
Variability Chart(
	Y( :Col1, :Col2 ),
	Model( "Main Effect" ),
	X( :unit )
If I have a list of columns that I would like to generate graphs for:
ListofColumnNames = dt << Get Column Names();
ListofColumnNames = {Col1, Col2, ...};
Is there a way to expand this list in line to create essentially the same comma separated list that JMP created?
Variability Chart(
	Y( Column( ListofColumnNames ) ),    // I know this syntax does not work, but conveys the intent.
	X( :unit )
I know that this can be accomplished using a For Loop
Y( Column(ListofColumnNames[i])),
but wondered if there was a way to avoid the For Loop and invoke the Variability Chart only one time by passing the entire list (for speed).
Re: Using a list of column names in a varability chart
Change the Column() function to an Eval() function and it should all work.  Here is a working example:
names default to here(1);
dt=
// Open Data Table: semiconductor capability.jmp
// → Data Table( "semiconductor capability" )
Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
remove from(ListofColumnNames, 1, 4 );
// Just so there arn't so many columns to analyze
remove from(ListofColumnNames, 10, 118 );
Variability Chart(
	Y( eval( ListofColumnNames ) ),    // I know this syntax does not work, but conveys the intent.
	X( :lot_id )
dt=
Variability Chart(
	X( :lot_id )
DSchweitzer
Thank you. That worked exactly as I wanted.
