Jackie_
Using Parse in contain
I am trying to iterate through the list and get the values from the summary_tb into the lists L1, L2, L3 if contained in Lists 1,2,3,4. I am stuck with Prase(lists[j]). Any advice? Thanks
dt = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
List1 = {"NPN1", "PNP1", "PNP2", "NPN2", "PNP3", "IVP1"};
List2 = {"PNP4", "NPN3", "IVP2", "NPN4", "SIT1"};
List3 = {"INM1", "INM2", "VPM1", "VPM2", "VPM3"};
List4 = {"SNM1", "SPM1", "NPN5", "EP2", "ZD6"};
summary_tb = (Data Table( "Semiconductor Capability" ) << Tabulate(
	Add Table(
		Column Table( Statistics( N, Mean, Std Dev ) ),
		Row Table(
			Analysis Columns(
				:NPN1, :PNP1, :PNP2, :NPN2, :PNP3, :IVP1, :PNP4, :NPN3, :IVP2, :NPN4, :SIT1, :INM1, :INM2, :VPM1, :VPM2, :VPM3, :PMS1, :SNM1, :SPM1,
				:NPN5, :EP2, :ZD6, :PBA, :PLG, :CAP, :PBA3, :PLG2, :PNP5, :NPN6, :PNP6, :PNP7, :NPN7, :PNP8, :IVP3, :IVP4, :IVP5, :IVP6, :PNP9, :NPN8,
				:NPN9, :IVP7, :NPN10, :N_1, :PBA1, :WPR1, :B10, :PLY10, :VBE210, :VTN210, :VTP210, :SIT2, :SIT3, :INV2, :INV3, :INV4, :INV5, :FST1,
				:FST2, :RES1, :RES2, :PNM1, :PPM1, :FNM1, :FPM1, :FST3, :FST4, :RES3, :RES4, :A1, :B1, :A2N, :A2P, :A2P1, :IVP8, :IVP9, :DE_H1,
				:NF_H1, :ESM1, :ESM2, :ESP1, :YFU1, :VPM4, :PBA2, :PBB1, :LYA1, :LYB1, :DEM1, :DEP1, :NFM1, :PLY1, :VDP1, :VDP2, :SNW1, :RSP2, :PLY2,
				:RSP1, :VDP3, :PBL1, :PLG1, :VDP4, :SPW1, :VIA1, :INM3, :VPM5, :VPM6, :INM4, :VPM7, :M1_M1, :M2_M2, :P1_P1, :E2A1, :E2B1, :NPN11,
				:IVP10, :PNP10, :INM5, :VPM8, :VPM9, :INM6, :VPM10, :N2A1, :N2B1, :NM_L1, :P2A1, :P2B1, :PM_L1, :P1, :M1
)) << Make Into Data Table;
lists = {"List1", "List2", "List3", "List4"};
///Get values from the below loop into these lists L1 = {}; L2 = {}; L3 = {};
// Loop to iterate rows and lists to find the column values from the tabulate table For( i = 1, i <= N Rows( summary_tb ), i++, For( j = 1, j <= N Items( lists ), j++, //// Something is not correct in the below code If( Contains( Parse (lists[j]) ,Column( summary_tb, 1 )[i]), Insert Into( L1, Column( summary_tb, 1 )[i] ); Insert Into( L2, Column( summary_tb, 2 )[i] ); Insert Into( L3, Column( summary_tb, 3 )[i] ); ) ) );
Re: Using Parse in contain
I was able to get the result you specified by using the Substitute function
L1 = {};
L2 = {};
L3 = {};// Loop to iterate rows and lists to find the column values from the tabulate table
		Eval(
			Substitute(
					Expr(
						If( Contains( __lists__, Column( summary_tb, 1 )[i] ),
				Expr( __lists__ ), Parse( lists[j] )
Jackie_
Thanks Jim!
Jackie_
@txnelson
Quick question - I want to get the a values in the tab box table box for each of the list
For instance,
The first tab box should have the following summary stats
The 2nd tab box should have the following summary stats
Likewise for 3 and 4
I tried using set function but it copies all the columns in the one tab. Any suggestions?
	Add Table(
		Row Table(
			Analysis Columns(
L1 = {};
L2 = {};
L3 = {};
		Eval(
			Substitute(
					Expr(
							Insert Into( L1, Column( summary_tb, 1 )[i] ); // Test
							Insert Into( L2, Column( summary_tb, 2 )[i] ); // N
Insert Into( L3, Column( summary_tb, 3 )[i] );// Mean Insert Into( L4, Column( summary_tb, 3 )[i] ); // Std ) ), Expr( __lists__ ), Parse( lists[j] ) ) ) ) ); Nw = New Window( "", Tab Box( "1", V List Box( tbb = Table Box( tests = String Col Edit Box( "Tests", {} ), num = Number Col Edit Box( "N", {}, <<set format( "Fixed Dec", 12 ) ), mean1 = Number Col Edit Box( "Mean", {}, <<set format( "Fixed Dec", 12, 2 ) ), std = Number Col Edit Box( "Std", {}, <<set format( "Fixed Dec", 12, 2 ) ), ) ), "2", V List Box( tbb = Table Box( tests = String Col Edit Box( "Tests", {} ), num = Number Col Edit Box( "N", {}, <<set format( "Fixed Dec", 12 ) ), mean1 = Number Col Edit Box( "Mean", {}, <<set format( "Fixed Dec", 12, 2 ) ), std = Number Col Edit Box( "Std", {}, <<set format( "Fixed Dec", 12, 2 ) ), ) ), "3", V List Box( tbb = Table Box( tests = String Col Edit Box( "Tests", {} ), num = Number Col Edit Box( "N", {}, <<set format( "Fixed Dec", 12 ) ), mean1 = Number Col Edit Box( "Mean", {}, <<set format( "Fixed Dec", 12, 2 ) ), std = Number Col Edit Box( "Std", {}, <<set format( "Fixed Dec", 12, 2 ) ), ) ), "4", V List Box( tbb = Table Box( tests = String Col Edit Box( "Tests", {} ), num = Number Col Edit Box( "N", {}, <<set format( "Fixed Dec", 12 ) ), mean1 = Number Col Edit Box( "Mean", {}, <<set format( "Fixed Dec", 12, 2 ) ), std = Number Col Edit Box( "Std", {}, <<set format( "Fixed Dec", 12, 2 ) ), ) ) ) ); tests << set(L1);
num<< set(L2);
mean1<< set(L3);
std<< set(L4);
The variables Tests, num, mean1 and std keep getting changed from the Display Objects in Tab 1, to Tab 2......Tab 4.  If you want to send your <<Set messages to each of them, you need to have different pointers to them.  See the code below
	Add Table(
		Row Table(
			Analysis Columns(
				:VPM1, :VPM2, :VPM3, :PMS1, :SNM1, :SPM1, :NPN5, :EP2, :ZD6, :PBA, :PLG, :CAP, :PBA3, :PLG2,
				:PNP5, :NPN6, :PNP6, :PNP7, :NPN7, :PNP8, :IVP3, :IVP4, :IVP5, :IVP6, :PNP9, :NPN8, :NPN9,
				:INV2, :INV3, :INV4, :INV5, :FST1, :FST2, :RES1, :RES2, :PNM1, :PPM1, :FNM1, :FPM1, :FST3,
				:FST4, :RES3, :RES4, :A1, :B1, :A2N, :A2P, :A2P1, :IVP8, :IVP9, :DE_H1, :NF_H1, :ESM1, :ESM2,
				:SNW1, :RSP2, :PLY2, :RSP1, :VDP3, :PBL1, :PLG1, :VDP4, :SPW1, :VIA1, :INM3, :VPM5, :VPM6,
				:INM4, :VPM7, :M1_M1, :M2_M2, :P1_P1, :E2A1, :E2B1, :NPN11, :IVP10, :PNP10, :INM5, :VPM8,
L1 = {};
L2 = {};
L3 = {};
L4 = {};
		Eval(
			Substitute(
					Expr(
	Tab Box(
		"1",
		V List Box(
			tbb1 = Table Box(
				tests1 = String Col Edit Box( "Tests", {} ),
				num1 = Number Col Edit Box( "N", {}, <<set format( "Fixed Dec", 12 ) ),
				mean11 = Number Col Edit Box( "Mean", {}, <<set format( "Fixed Dec", 12, 2 ) ),
				std1 = Number Col Edit Box( "Std", {}, <<set format( "Fixed Dec", 12, 2 ) ),
		"2",
		V List Box(
			tbb2 = Table Box(
				tests2 = String Col Edit Box( "Tests", {} ),
				num2 = Number Col Edit Box( "N", {}, <<set format( "Fixed Dec", 12 ) ),
				mean12 = Number Col Edit Box( "Mean", {}, <<set format( "Fixed Dec", 12, 2 ) ),
				std2 = Number Col Edit Box( "Std", {}, <<set format( "Fixed Dec", 12, 2 ) ),
		"3",
		V List Box(
			tbb3 = Table Box(
				tests3 = String Col Edit Box( "Tests", {} ),
				num3 = Number Col Edit Box( "N", {}, <<set format( "Fixed Dec", 12 ) ),
				mean13 = Number Col Edit Box( "Mean", {}, <<set format( "Fixed Dec", 12, 2 ) ),
				std3 = Number Col Edit Box( "Std", {}, <<set format( "Fixed Dec", 12, 2 ) ),
		"4",
		V List Box(
			tbb4 = Table Box(
				tests4 = String Col Edit Box( "Tests", {} ),
				num4 = Number Col Edit Box( "N", {}, <<set format( "Fixed Dec", 12 ) ),
				mean14 = Number Col Edit Box( "Mean", {}, <<set format( "Fixed Dec", 12, 2 ) ),
				std4 = Number Col Edit Box( "Std", {}, <<set format( "Fixed Dec", 12, 2 ) ),
tests1 << set( L1 );
num1 << set( L2 );
mean11 << set( L3 );
std1 << set( L4 );
tests2 << set( L1 );
num2 << set( L2 );
mean12 << set( L3 );
std2 << set( L4 );
tests3 << set( L1 );
num3 << set( L2 );
mean13 << set( L3 );
std3 << set( L4 );
tests4 << set( L1 );
num4 << set( L2 );
mean14 << set( L3 );
std4 << set( L4 );
