Using JSL script to sort a column in a data table using List Check or Value Order property
Hi all,
I'd like to use the List Check feature or the Value Order column property to custom sort a column in a datatable. This data table is created from a subset of another data table, but I am unable to get the property to custom sort the values in the data table. The relevant commands I'm using is as listed below:
dt_summary_table = (Data Table( "Name of table" )) << Make Into Data Table; // This works fine and created a datatable.
//Using List Check property
dt_summary_table << Column( "Column_name_eg_Names" ) << Set Property(
    "List Check",
    {"OrderList_A", "OrderList_B", "OrderList_C"}
// Or using Value Order property
    "Value Order",
//or using List Check property
dt_summary_table << Column( "Column_name_eg_Names" ) << List Check( {"OrderList_A", "OrderList_B", "OrderList_C"} );
dt_summary_table << Column( "Column_name_eg_Names" ) << Value Order( {"OrderList_A", "OrderList_B", "OrderList_C"} );
Could someone please advise what might be going bad or best way to sort the column values in custom sort order while displaying graphs/ plots etc.
I'm using JMP15 on Windows10.
Re: Using JSL script to sort a column in a data table using List Check or Value Order property
In JMP 15 the structure of the column property Value Order changed.  Here is an example of the new structure
names default to here(1);
dt=open("$SAMPLE_DATA\big class.jmp");
dt:sex<<set property("value order",{Custom Order({"M", "F"})});
dt << sort( by(:sex), replace table(1));
I suggest that you manually set the Value Order you want, and then use << get property("value order") to see how you need to structure your statement for your data
Thanks Jim/@txnelson very much,
This works now.
Just wondering if this new structure is documented somewhere ? I was following the documentation at https://www.jmp.com/support/help/en/15.0/#page/jmp/column-properties-3.shtml# which doens't seem to reflect the custom order syntax.
I agree with you that the documentation is in error.
