FN
FN
Recording and recovering metadata in a table
I have a stacked data table with three columns that contain strings and another numeric.
A: unique identifier
B: text
C: text
As, Bs, Cs, Values
A1, B1, C1, value11
A1, B1, C1, value12
A1, B1, C1, value13
A2, B2, C2, value21
A2, B2, C2, value22
A2, B2, C2, value23
Right now, I am creating a concatenated column name with the form "A (B) [C]" which I split to have the final table like so:
A1 (B1) [C1],  A2 (B2) [C2],
Value 11,        Value 21
Value 12,        Value 22
Value 13,         Value 23
I want to create a new column property that saves the As in this final table.
Do I need a loop with two lists to insert this property column by column?
Re: Recording and recovering metadata in a table
Can you provide an example of what the contents of the new column property would look like?
FN
FN
Sure.
Column: A1 (B1) [C1]
A_property: A1
Column: A2 (B2) [C2]
A_property: A2
If I understand correctly what you want - You have the property value already in the column name so you can could get it from there:
dt = New Table("Untitled",
	Add Rows(3),
	Compress File When Saved(1),
	New Column("A1 (B1) [C1]",
		Character,
		"Nominal",
		Set Values({"Value 11", "Value 12", "Value 13"})
	New Column("A2 (B2) [C2]",
		Character,
		"Nominal",
		Set Values({"Value 21", "Value 22", "Value 23"})
colNames = dt << Get Column Names("String");
For(i = 1, i <= N Items(colNames), i++,
	aVal = Word(1, colNAmes[i]);
	Column(dt, colNames[i]) << Set Property("A_property", aVal);
FN
FN
Sometimes As can have the pattern "abc (cde)" so better to use a mapping from the first table instead of Word().
is there a JSL dictionary we can use so the key is the column name and the value is the new property to save?
{"A1 (B1) [C1]": "A1",
"A2 (B2) [C2]": "A2"}
Check out Associative Arrays
