dfusco923
Using JMP Script to Populate a Column with Data
In the attached JMP data set there is a Character, Nominal "Cost Set" column.  It is not populated with Data yet.
I have scrip that can populate all the cells with "ETC" :
For Each Row(:Cost Set  =  "ETC")
However what I would like to do is if the :Label column is equal to "May ACWP" I'd like to populate the :Cost Set column with "ACWP", otherwise the :Label column = "ETC"
Can someone help me with the script to do this?
3 ACCEPTED SOLUTIONS
Re: Using JMP Script to Populate a Column with Data
For Each Row(
     If( :Label == "May ACWP",
          "ACWP",
          "ECT"
Please take the time to read the new user documentation, Discovering JMP, available under the Help pull down menu.
:Cost Set << Set Each Value( If( Contains( (:label column << Get Name ), "ACWP" ), "ACWP", "ETC" ) )
dfusco923
Hello Jim - Sorry for the delayed response thank you for providing the script for this - Dan F.
For Each Row(
          "ACWP",
          "ECT"
dfusco923
dfusco923
Hello Mark - Sorry for the delayed response thank you for providing the script for this - Dan F.
