ndowidar
Using Graph Builder is it possible to manually move reported Means and St Devs?
Using Graph builder I'm struggling to make graphs that list the mean and standard deviations of box plots. I discovered I could use the boxplot & Line of Fit to report the means and stardard devs next to each factor, but the reported numbers are oddly positioned. I was hoping there would be a way to simply manually move these values on the graph so that the overall graph looks better. Is there a way to do that? Also, I noticed the means are not in the same units as the Y-axis. Is there a way to change that as well?
 I've highlighted an example below:
Re: Using Graph Builder is it possible to manually move reported Means and St Devs?
Hello @ndowidar ,
It may be different from what you want, but another approach is to use the Caption Box.
- Click the Caption Box icon.
- In the Caption Box options on the left side of the plot, select Graph per Factor from Location.
- You can change the Y-position from the option
If you right click on the graph, you can select Customize to move the caption text.
I hope this works.
